Home > Message Board > Portable Electronics > Headphones > Which Headphones are Best?
Author Thread: Which Headphones are Best?
Username: Blahpoopy
Santa Cruz, CA
United States
Hi everyone!
I've been drooling over earphones on cnet but cant seem to decide which is best and affordable. I am looking to purchase earphones for my boyfriends birthday. He likes to jog and so I want to find something that will sound good (he listens to indie and hip hop and all that lays in between). I would love to find earphones that can also be used during travel so as close to noise cancelling as it can get without being actual noise canceling headphones as well as the ability to make it sound good but hear his surroundings (i do not want him to get hit by a car). These are the ones I'm looking at, any thoughts?
http://reviews.cnet.com/headphones/skullcandy-full-metal-jacket/4505-7877_7-3339 7065.html
http://reviews.cnet.com/headphones/skullcandy-chops-headphones/4505-7877_7-33632 123.html
http://www.bestbuy.com/site/olspage.jsp?skuId=9251061&type=product&id=1218071976 475
Thanks SO much
Username: Edison
Glendale, CA
US
Post Number: 901
This one sounds better than the 3 you mentioned - and is affordable:
http://cgi.ebay.com/Sennheiser-CX500-white_W0QQitemZ260458648614QQcmdZViewItemQQ ptZOther_MP3_Player_Accessories?hash=item3ca48b9426&_trksid=p4295.c0.m313
However, prolonged hearphone listening if bad for the ear - so you might want to ask your boy friend to turn down the volume as much as possible, if he has to listen at all. perhaps you should get him a mini system to save his hearing - if you want to go this rout, post it on the mini forum and you will get responses.
Username: Andreas
Post Number: 32
sennheiser is a decent brand, there is also shure, and beyerdynamic - and on a cheaper end - creative labs. Try to listen before you buy
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Portable Electronics > Headphones > Which Headphones are Best? [ « Previous ] [ Next » ]
