Thread: Sennheiser HD-201 vs. JBL Reference 410 |
Gold Member Username: Exerciseguy
Brooklyn,
NY
United States
Post Number: 2100 Registered: Oct-04
| Posted on Wednesday, October 29, 2008 - 10:38 pm: |
I've owned both these heat sets for a while and I thought I jot down some impressions. These two headphones are about the same price, are about as well built as each other, but the could not sound more different. Sennheiser HD-210 I pick these up for under $15 online somewhere about 2-years ago and they've served me well as a basic "around the house" headphone. They are forward sounding, have very good mid-range resolution, and are comfortable; however, they do get hot for extended listening, and are very thinnish in the bass category. If you like thumping bass-lines, look elsewhere. JBL Reference 410 I bout these a few months back also for about $15, but haven't had the opportunity to listen to them thoroughly until recently. The 410s are a solidly build, folding design, one that provides a very tight fit that is perhaps a bit too tight, and also a bit hot, I found them to be slightly uncomfortable, but they do create a tight seal, that lends itself to the heavy bass sound of the 410. This headphone is all about the bass, bass is up front, solid, and omnipresent, mid-rage sadly is setback and muddy, which doesn't make for very pleasant listening in my book. The Winner: The Sennheiser HD-210. |
Brooklyn,
NY
United States
Post Number: 2101 Registered: Oct-04
| Posted on Thursday, October 30, 2008 - 07:46 am: |
Sorry for the typos above, obviously I meant the Sennheiser HD-201, not 210. ...and headphone not "heat set"??? |
New member Username: Gregoryt
White Plains,
New York
United States
Post Number: 2 Registered: Jan-09
| Posted on Saturday, January 24, 2009 - 09:07 pm: |
Just learned something new, I did not know that JBL, made headphones. |
Brooklyn,
NY
United States
Post Number: 2326 Registered: Oct-04
| Posted on Sunday, January 25, 2009 - 08:41 am: |
They do, sort of, the Reference 410 are actually re-badged AKG K26P, another Harman company, |
White Plains,
New York
United States
Post Number: 5 Registered: Jan-09
| Posted on Sunday, January 25, 2009 - 05:00 pm: |
Okay, gotcha, thanks for clearing that up. |
