Thread: Samsung SGH-U700 |
Silver Member Username: Lolol
Post Number: 304 Registered: Sep-06
| Posted on Friday, June 06, 2008 - 04:32 pm: |
I just purchased Samsung SGH-U700 and paid alot of money for it (but its unlocked and tri band phone)but anyways, the reception in this phone is very bad compare to the moto razr I had before. I was wondering if there is some kind of a setting I have to do or what within the phone to make the reception better or whatever is possible to make it work a little better. any help is appreciated I use this phone in Canada and the service provider is Rogers. Thanks |
Relevant Product Info
Gold Member Username: Dude123
Post Number: 2348 Registered: Jul-06
| Posted on Friday, June 06, 2008 - 07:30 pm: |
lolol, Rogers work on the 850/1900 band and U700 doesn't have 850 band built in, it only has 1900 band thats the reason your phone doesn't have a good reception. Some times you can find a signal boosters from a private shop and/or you will have to get a phone that has 850/1900 band built into it in order for it to work for Rogers. |
Post Number: 305 Registered: Sep-06
| Posted on Saturday, June 07, 2008 - 01:24 am: |
Thanks NW, I guess I will have to sell this phone then and get something that would work better with Rogers. |
