Thread: GENX 2GB music key problem... |
New member Username: Slow86
Post Number: 1 Registered: Jan-08
| Posted on Friday, January 18, 2008 - 06:46 am: |
Hi.. My name is Umair and i had bought my musci key which 2 GB and at first it was working perfecty...but after some time it has stopped working...First i thought that it was battery problem but after changing thre battery packs it still wont work..The usb works but when want to listen to my songs it doesn't turn on...i had recently updated my firmware but nothing happened...pls help |
Platinum Member Username: Project6
Post Number: 14358 Registered: Dec-03
| Posted on Friday, January 18, 2008 - 09:45 am: |
Have you tried their tech support? |
Post Number: 2 Registered: Jan-08
| Posted on Sunday, January 20, 2008 - 03:04 am: |
i have posted the problem there also but didnt get any response as of rite now... |
Post Number: 14388 Registered: Dec-03
| Posted on Sunday, January 20, 2008 - 10:49 am: |
That should tell you the level of quality of your MP3 player. How old is the player? |
Post Number: 3 Registered: Jan-08
| Posted on Sunday, January 20, 2008 - 01:03 pm: |
just bought it 8 months ago..can u help...plz |
