Thread: How to upload pictures/videos onto 8gb ipod nano, the new video one...plz help |
New member Username: Natty01
Post Number: 1 Registered: Nov-07
| Posted on Wednesday, November 28, 2007 - 07:57 pm: |
Hi i need help with uploading pictures to my ipod. Ive tryed by simply clicking and dragging the picture from its file then into itunes, but it always comes up with the message saying that the ipod cannot 'play' the image, then i try thru itunes by clicking the tab at the top that says pictures, when i try it that way it says that it will erase all existing data on the ipod first, i dont want that!...i gave it a go anyway, but when i want to add more photos on top of that later on it gets rid of the photos already on the ipod then uploads the new ones. How can i make it so that i can upload photos without having this problem of everything else deleting and i want to be able to add more photos later on without a problem. And about the video, ive tryed putting a video on, but itunes spends aggggges like verifying the video or something, but when it eventually gets onto my ipod the video plays fine but with no sound! how can i fix this someone help me please } |
Platinum Member Username: Project6
Post Number: 14761 Registered: Dec-03
| Posted on Friday, February 08, 2008 - 01:06 am: |
First you need to convert all the video files you want to put in your iPod to MPEG_4. It won't play any other format. Let us deal with one issue at a time. |
New member Username: Thermo
Post Number: 1 Registered: Feb-08
| Posted on Saturday, February 16, 2008 - 11:10 am: |
I have the same problem, when I try to add some videos he says that he will erase all existing data on the ipod. anybody can help me? |
Post Number: 15074 Registered: Dec-03
| Posted on Saturday, February 16, 2008 - 12:10 pm: |
Change the way your iPod manages music or media. Put it on manual management. |
New member Username: Mymusic
Post Number: 3 Registered: Jan-08
| Posted on Tuesday, November 04, 2008 - 10:25 am: |
to add photos on and off your ipod by just dragging them into the folder or album that you want, you need to use this Photo app. If you want to copy all your videos, podcasts, artworks back to your pc or itunes use this software. I'll automatically import whatever you want in the right order.  |
New member Username: Hotmilk22
Post Number: 3 Registered: Jul-09
| Posted on Friday, July 24, 2009 - 06:19 am: |
I tried Aiseesoft iPhone Ringtone Maker, it is really very easy to use and powerful, and it also have a Mac version, which is Aiseesoft iPhone Ringtone Maker for Mac. |
