Thread: Region unlock code for Philips PET702/37 |
New member Username: Lolekibolek
Post Number: 1 Registered: Aug-07
| Posted on Wednesday, August 01, 2007 - 08:36 am: |
Hi, does anyone have the code for this player? thanx |
New member Username: Dannyk100
Post Number: 1 Registered: Nov-07
| Posted on Wednesday, November 28, 2007 - 08:32 pm: |
try this: Press setup on the remote Use the arrows to navigate to Prefreneces (pref) type 9 6 5 3 Select Region code (press down arrow to set to 0, open for all codes) Press setup again to exit |
New member Username: Keinoguchi
Post Number: 1 Registered: Dec-08
| Posted on Friday, December 12, 2008 - 09:45 pm: |
By the way, you should take your DVD disk out from the tray otherwise they don't let you select the preference tab explained above. Just two cents. |
New member Username: Touristinthecity
Post Number: 1 Registered: Mar-09
| Posted on Wednesday, March 11, 2009 - 12:58 pm: |
Thanks from me as well. Worked like a dream. This Philips PET702 has been a great little machine. |
