Thread: Hi, im having toubles finding headphones that fit in my MP3 |
New member Username: Psykith
Post Number: 1 Registered: Mar-07
| Posted on Monday, March 26, 2007 - 11:12 pm: |
Yah i just bought a new Curtis MP3 player and the headphone jack is to small for regular headphones to fit in it.Can someone tell me what this is called and tell me if i can just cut the smaller jack off and put it on a set of regular headphones? |
Gold Member Username: Illuminator
Post Number: 4897 Registered: Apr-05
| Posted on Saturday, March 31, 2007 - 04:15 pm: |
How small are we talking here? Can you find a picture of the adaptor? |
Post Number: 2 Registered: Mar-07
| Posted on Tuesday, April 03, 2007 - 12:39 am: |
srry i dont have a picture of it but i would say its about 3mm jack. |
Post Number: 3 Registered: Mar-07
| Posted on Tuesday, April 03, 2007 - 12:40 am: |
ohh, srry it about a 2.5mm jack not 3mm. |
Post Number: 4 Registered: Mar-07
| Posted on Tuesday, April 03, 2007 - 12:44 am: |
the only headphones i found that would fit are cell phone headsets. |
Post Number: 4967 Registered: Apr-05
| Posted on Tuesday, April 03, 2007 - 04:49 am: |
They make an adaptor which should work fine for you: http://www.amazon.com/Smartphone-Stereo-Headphone-Adapter-2-Pack/dp/B000KG8JHK There is also a solid piece connector: http://www.cuc.fr/cuc.en/liaison/multimedia/72055.jpg Hope that helps.  |
