Thread: No Disc error! Portable Polaroid DVD Player |
New member Username: Boxer808
Honolulu,
HI
Post Number: 1 Registered: Jan-07
| Posted on Sunday, January 21, 2007 - 08:26 pm: |
When inserting a dvd or disc, it'll say loading, then it'll say NO DISC. What could be wrong? |
Silver Member Username: Nikk
Post Number: 985 Registered: Sep-06
| Posted on Wednesday, January 24, 2007 - 11:29 pm: |
Get some lens cleaning solution and a q-tip, gently clean the lens without putting pressure on it....also check if it is properly positioned, you can move the lens arrangment a little bit, when you turn it on it must go back to its position... |
