Thread: Palm treo 650 |
Bronze Member Username: Djrob_1
Post Number: 15 Registered: Dec-06
| Posted on Thursday, January 11, 2007 - 08:20 pm: |
just got a 650 does anybody know if i can use it as a modem to access the internet on my computer? |
Silver Member Username: Impala63rag
Post Number: 363 Registered: Sep-06
| Posted on Wednesday, January 24, 2007 - 02:43 am: |
I dont know about that but i've had one for a year now and i love it. I have 9 gigs of san disk cards full of music and videos, an Nintendo immulator, i can even use it as a remote for t.v. or whatever. My contact dialog is extensive, texting is great, calender is usefull, all my call groups are ring sensitive so i know who it is before i look. definitely recommend Ringo, Z launcher, tcpmp (for video), ljp, super utility, realplayer |
Post Number: 364 Registered: Sep-06
| Posted on Wednesday, January 24, 2007 - 02:45 am: |
p.s., im usually on car audio/subwoofer. just incase ya had a question about one of those programs. |
Post Number: 16 Registered: Dec-06
| Posted on Wednesday, January 24, 2007 - 08:15 pm: |
thanks man hey are those websites |
New member Username: Eyedoc
Hamden,
CT
United States
Post Number: 1 Registered: Sep-07
| Posted on Sunday, September 09, 2007 - 09:37 am: |
How do I convert my ITunes library to WMA format in order to download tunes to expansion card for Treo 650? My Treo won't play MP3 format that I currently use for IPod. Thanks for any help. EyeDoc} |
Post Number: 29 Registered: Dec-06
| Posted on Sunday, September 09, 2007 - 11:40 am: |
thats weird because mine plays mp3 just fine but the easiest way is to get on downloads.com and find a music file converter. Hope that helps |
Hamden,
CT
United States
Post Number: 2 Registered: Sep-07
| Posted on Sunday, September 09, 2007 - 12:35 pm: |
Thx, But how did you get your MP3 music into the Treo? I can put albums onto the expansion card, but when I put the card into the Treo, it sees the card but says the card has nothing on it. Thx Jeff |
Post Number: 30 Registered: Dec-06
| Posted on Sunday, September 09, 2007 - 09:20 pm: |
i got on palms website and got the palm desktop and quick install added the files to my card and then opened realplayer on the phone and they worked just fine. |
