Home > Message Board > Portable Electronics > Portable MP3 Players > Archive through March 03, 2007 > How do I get these Free Videos to wor...
Author Thread: How do I get these Free Videos to work on my Ipod?
Username: Jjforreal
Can someone tell me how to get these Mp4's Videos to work on my Ipod? I found this site, but I can’t figure out how to load them into my ipod?
http://feeds.feedburner.com/OnlyFreeMoviesAndVideos
Any help is much appreciated!
Username: Project6
Post Number: 12332
You have to convert them to a video format that is compatible with the iPod.
Username: Jjforreal
I think MP4 is the format for ipod. Is there a program I need?
Username: Dkchillin
Vermont
Post Number: 363
If you have the latest iTunes version you sould have a playlist called videos. Open iTunes and that playslist. Go to the site you linked and right click (ctrl+click if you're using a Mac) and "save as" to your desktop. Then take that file from your desktop, click and drag it into iTunes. It should add the video to iTunes, then just sync your iPod and it should be there under videos.
If, for some reason, you do need to convert the videos (which you shouldn't since they're already in mp4) or any video for that matter, I'd reccomend the Videora converter. It takes some time to convert files but it's worth it. You can get the Videora converter here.
Username: Jjforreal
Hi Darek Fanton,
Itunes did the trick. I just imported into my Libabary and was able to Dl them. Thanks for the help man!
Another Question…… does anyone know if the new iphone is going to have video? Also how much did they say it’s going to cost?
Home > Message Board > Portable Electronics > Portable MP3 Players > Archive through March 03, 2007 > How do I get these Free Videos to wor... [ « Previous ] [ Next » ]
