Home > Message Board > Portable Electronics > Portable MP3 Players > Phillips Mp3 Gogear help
Author Thread: Phillips Mp3 Gogear help
Username: Antiwinter
Phoenix, Arizona
My daughter has a phillips mp3 player. Last week it locked up hard. Took the back off to try and unplug battery thinking it might solve the problem. Well it did for one day. Now it is off and wont turn back on even on the charger. Any suggestions? The player is about 1 year old.
Thanks in advance
Username: Your_mom890
it sounds to me like the battery is shocked and not the mp3 player. i would try taking off the battery for at least ten minutes and then putting it back on. if that fails try getting a new battery.
Username: Ac_dc
Post Number: 8
HI,
Not knowing the model, have you tried resetting the device, if it does not have a reset button, I think you can reset by holding down the menu button then the power button together for a few seconds, or a different model might have you hold down the volume up button and the power button as described above. Otherwise, if it detects on your computer, try reloading the firmware... back up your files first if you can. Regards, Ter'
Username: Sathan9890
i have a philips mp3 model HDD082/17. last week i tried to upgrade the firmware and tried to sync some songs...but it crashed and now only the philips screen is only comming with a tick sound.when connecting to the pc,it is not recognizing . help me what to do???????
Username: Neosoul9
I have the same mp3 player as the person above me and the same problems. Is there anyone that can help solve these issues?
Username: 70457
hey i have a philips gogear hdd14xx 8gb and the only trouble ive had w/ it is putting pics on it i drag the pics into the pictures directory but then when i unplug it and i look in the pictures directory theres nothing their im slightly depressed over this how to get this to work
Username: Sammy_d_8
Urm I've Got A Phillips Go Gear 512 MB MP3 player, and I put it into the computer, and copied lots of songs onto it from myMusic, however, when I try to find them, I can't! Help!
Username: Seks21
Las vegas, Nv
}hello there i have an hdd077/17
and i cant get it to work....everytime i unplug it it shows an error screen what can i do to get it off....
i think i need the files for this player...
Username: Nacho1925
Hamilton, Waikato
New Zealand
Hae i have philips mp3 anbd when i was watching a video clip it just froze and said playlist error or something, then it turned off and i can get it to turn back on.i tried putting it on the charger and nothing happens!help!Upload
Username: Mina0805
hi,
how do i delete "read only files" from my mp3 player?
I don't know how they were saved as read-only and i can't get rid of them now.
Help!!!
Thanks.
Username: Kellyt2112
Okay so my Go Gear MP3 froze on the "do not disconnect" screen, I reset the MP3 but now it is not starting up! Ugh.. help anyone?
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Portable Electronics > Portable MP3 Players > Phillips Mp3 Gogear help [ « Previous ] [ Next » ]
