Thread: Ipod Help Please!!! |
New member Username: Miacanes
Post Number: 8 Registered: Aug-06
| Posted on Tuesday, October 03, 2006 - 10:44 pm: |
i had to reboot my computer so all my songs erased. there still on my ipod is there a way to sync the songs and photos to the new library. thx |
Platinum Member Username: Project6
Post Number: 11248 Registered: Dec-03
| Posted on Tuesday, October 03, 2006 - 11:36 pm: |
No easy way. The transfer is one way...from PC to iPod only. Keeps from pirating and distributing. Look for an iPod hack that can do that. Google it, there are plenty. But there is no guarantee that it will not mess up your iPod. Next time, back up all your music files to a removable disk. |
Silver Member Username: Kklagge
Post Number: 326 Registered: Dec-04
| Posted on Friday, October 06, 2006 - 06:07 am: |
download ipod agent...works good for going from ipod to computer |
New member Username: Redwards
Regina/Kelowna,
Sask./B.C.
Post Number: 4 Registered: Oct-06
| Posted on Tuesday, October 31, 2006 - 10:55 pm: |
Plug in the iPod, go to it through My Computer, show hidden folders (Tools, Folder Options, the View tab, "Show hidden files and folders"), iPod_Control, Music, and then start copying and pasting the songs from the folders to your My Music folder. Once you have them all in there, set your iTunes preferences to "Organize my iTunes music folder" and then open the songs (or drag them from the My Music folder to the iTunes window). The names should change from things like "ABCD.mp3" and "WXYZ.mp3" to their regular names. ps. ive never tried this, but apparently it works. |
