Thread: Versatile use of PSP , let's music |
New member Username: Anita12
Post Number: 6 Registered: Jun-06
| Posted on Wednesday, August 09, 2006 - 01:12 am: |
As you know, PSP is not only used for games, but also for videos and of course music. But have you been pulling your hair out while trying to download music to your Sony PSP? Take it easy, in fact there are only a few steps needed to make this whole process a piece of cake. Then follow me through this recipe. 1. First of all, what you need is something we call it a cd ripper and while you are at it I would then seize a psp video converter. A cd ripper ( such as Xilisoft cd ripper or icesum cd ripper) helps you pull music (rip) of your cd's that you have at hand. Then the psp video converter ( PSP video 9 or Imtoo PSP converter) will let you rip and convert video files to watch on your PSP...After these two steps, you can watch and listen to music videos and music, really amazing? Definitely 2. Load your cd and fire up your cd ripper select songs you want to put on your PSP and hit the "extract and encode" to PSP. Interface of some software is really very user-friendly , with many settings you can customize to meet your favorite expectations. Xilisoft¡¯s interface supports multi-language demonstration. 3. If you already have music files on your pc then all you need to do is hit "add" from your cd ripper or psp video converter. 4. Throughout the process, you should make sure you select the "PSP" format for each conversion. 5. As to transferring your music to PSP, you need only to connect your PSP with your PC with the USB cable, and copy your mp3 file(s) into "H:PSPMUSIC" Then after these simple 5 steps, you can enjoy music on your cute PSP, and of course you can also download those tons of music out there on the Internet and load them to your PSP. Still a bit confused about what the best converter you should choose? You can log-in these two sites : http://www.sharewareguide.net/ for converter tools and this site http://www.us.playstation.com/PSP/Support for technical helps. |
Relevant Product Info
Bronze Member Username: Ailsa010
Post Number: 15 Registered: Jun-06
| Posted on Friday, August 11, 2006 - 03:39 am: |
i still favor my iPod to listen to and watch music, PSP is PSP anyway , for games! |
Gold Member Username: Illuminator
Post Number: 3953 Registered: Apr-05
| Posted on Friday, August 11, 2006 - 11:55 pm: |
PSPs dont' have much memory on them regardless of the mem stick you use. Not practical for music-the sound quality is so-so. |
Post Number: 9530 Registered: Dec-03
| Posted on Saturday, August 12, 2006 - 12:00 am: |
Defeats the whole purpose of a practical portable MP3 player, doesn't it? |
Post Number: 7 Registered: Jun-06
| Posted on Tuesday, August 15, 2006 - 05:14 am: |
well , i never meant that PSP is able to match some MP3 players, only that there is a possiblity to make ur PSP more versatile |
