Thread: I cant put songs from cd to ipod! |
New member Username: Seeniee
Post Number: 1 Registered: Jul-06
| Posted on Monday, July 24, 2006 - 01:24 pm: |
please please help me!how do u put songs from cd onto ipod nano?explain in detail coz im not very computer friendly!! |
Relevant Product Info
Post Number: 8865 Registered: Dec-03
| Posted on Monday, July 24, 2006 - 05:45 pm: |
When you open iTunes, insert your CD. When iTunes activates, iTunes will list the names of the songs on your CD. Look on the upper right hand corner of iTunes. You will see a circular icon with a label that reads "Import CD" Click on this button and your CD will be imported into your iTunes librabry. Read your manual, for details. If you don't have a manual you can contact tech support at apple.com |
New member Username: Kevintsa
Post Number: 9 Registered: Jun-06
| Posted on Monday, August 07, 2006 - 05:24 am: |
you can also try Imtoo cd ripper, a very useful cd able to rip cd into many popular audio formats. |
New member Username: Ailsa010
Post Number: 5 Registered: Jun-06
| Posted on Tuesday, August 08, 2006 - 09:08 pm: |
I also once used Imtoo cd ripper, a recommendable tool, BTW, cucusoft is also easy to use, but with less supported formats |
Post Number: 9362 Registered: Dec-03
| Posted on Tuesday, August 08, 2006 - 11:40 pm: |
But why use more programs than is absolutely necessary to run only what you need? That is one reason why there is a lot of conflict in systems, too many programs running the same thing. |
Bronze Member Username: Kevintsa
Post Number: 21 Registered: Jun-06
| Posted on Thursday, September 28, 2006 - 12:44 pm: |
if you use imtoo cd ripper,you won't say like that,just as easy as you can imagin. |
