Thread: RCA Lyra RD2762: File System Corrupt. |
New member Username: Xxpigxx
Post Number: 1 Registered: Jul-06
| Posted on Friday, July 07, 2006 - 09:28 pm: |
Hello. I have been going through these threads, but I have a problem that has not ben addressed. My brother gave me his RCA Lyra RD2762, with the installation CD. I installed the Lyra application, and tried to run it, but it does not show in the system tray, although it shows as a process when I chech with alt+ctrl+del. Therefore, I cannot upgrade the firmware, which sucks because I get the File system corrupt message. I can get the icon to show by ending explorer.exe and starting it again. But when I right click, all the menu options are grayed out, and the icon disappears. The player does not show in My Computer as a drive, and it will only play the USB sound if I hold the control stick on the player while plugging in the USB cable. WHat's more . . . it goes to the transfer screen, but 10 seconds later, it shows the safe to disconnect message, without any prompting fromn me. Can someone please help me? Thank you. |
New member Username: Jrharden
Post Number: 2 Registered: Aug-06
| Posted on Wednesday, August 23, 2006 - 11:42 pm: |
I'm having the exact same problem...it's hard to fix it when your computer wont even read it... |
