Thread: Archive through August 11, 2005 |
Njsurfer19238 Unregistered guest |
| Posted on Thursday, November 11, 2004 - 09:12 pm: |
I'm having trouble with my mp3/video player. It worked fine untill I restarted everything on my computer. Now since I put 4 songs on it, the lyra will not start. It goes through about 2 seconds of loading then shuts off. Please send any help you can..im so frustrated! thanks |
Relevant Product Info
RcaSupport Unregistered guest |
| Posted on Friday, December 24, 2004 - 06:29 pm: |
Delete the songs off your lyra, press the restart button. Reinstall firmware, software. Then Start Again. -Rca Support |
| Posted on Wednesday, January 05, 2005 - 12:43 pm: |
To RCA support, Is there a tool available to do a factory software reset of the unit after you are confronted with the Loading.. screen? |
| Posted on Monday, January 10, 2005 - 07:46 pm: |
The ear phone plug fell into my lyra and so I took off the back and unplugged the memory, got out the little plug and put it back and now it will not start and I also pushed the reset button. But now it will not start.... HELP me please |
Post Number: 2406 Registered: Dec-03
| Posted on Tuesday, January 11, 2005 - 07:47 am: |
for LYRA problems go here http://www.rcaaudiovideo.com/Cultures/en-US/DownloadsLanding.html |
| Posted on Monday, January 24, 2005 - 11:59 am: |
How do I delete all the demo songs put on the player by default? |
| Posted on Wednesday, January 26, 2005 - 09:16 pm: |
is there anyway to record dvds onto my lyra? |
| Posted on Thursday, January 27, 2005 - 09:47 am: |
Hello: To RCASupport: Can the RD2780 playback to a standard TV (assuming the TV had the correct A/V inputs)? Thx: RobH |
| Posted on Saturday, January 29, 2005 - 05:27 pm: |
i just bought the RCA LYRA RD2780 and i dont not understand how to download the videos please help me!! |
| Posted on Wednesday, February 02, 2005 - 06:30 am: |
I am in the UK and the Lyra support page doesn't allow me to get support without a valid US Zip Code. The drop down for the name of the product doesn't list the juke box, and the menu items of the Product type is Audio, Lyra digital audio player, DVD, and VCR. the Lyra I've got is a audo/vidoe jukebox but there's no selection for non of the above. |
| Posted on Thursday, February 03, 2005 - 08:40 am: |
How do I get a replacement hard disk. The Lyra I've got is no longer mountable on the PC and the MP3 files on the disk are no longer readable. It comes up with a message missing system files when it's switched on... or am I doing something wrong?
Tech Guy Unregistered guest |
| Posted on Friday, February 04, 2005 - 02:48 pm: |
Hey everybody this is "Tech Guy" doing his day of service. (its what keeps me out of hell!) lol j/k ok here we go Ok FJV yes there is a tool go to: http://www.rcaaudiovideo.com/Cultures/en-US/DownloadsLanding.html remove all data on the Lyra the run the install process and it should reboot. To: Anonymous why did you take off the back and UN plug anything? You do realize there is a factory warranty for 90 days. You violate that by opening it. To: Lyra yes you can. Just plug it in and it browse to it from Windows Explorer And delete them their. To: Curt yes you can record DVD’s there are a few ways to go about this. The first and most obvious way is to use the on board recording system of the Lyra. 1. record strait to Lyra (this works for live television as well.) Just hook it up to the DVD player. Wait for a signal and play the movie then start recording. But in my opinion the Lyra Dose not compress video as well as a computer. So I like to do it on the PC. 2 . Record DVD’s to pc Recording DVDs to your computer then compressing them to an MPEG 2 or MPEG 4 isn’t much harder and can produce video that’s smaller and has better quality go to www.slysoft.com and get there decoder software. (Its really worth the buy if you ask me) then go to www.dvd2svcd.org and download there DVD2AVI converter. Convert to MPEG 4 or 2 and your set. Just transfer that to the Lyra and it works like a champ. But either way works. To: RobH yes just connect the transfer AV cables to the transfers out jack on the side of the Lyra and connect to TV. To: Kethm you really need to read the users manual from page 18-30 and it will explain every thing. After that if you have a question on a specific thing I can help you. To: John Dutton umm John you cant just replace the HD in the Lyra its probably easier to get a new one. But what it look like is the hard drive on your Lyra might have corrupted there are a couple ways this could have happened. Strong Static shock, power surge, near a strong magnet (most likely) if you put it near a Big TV speaker or something. ECT. Either way the best plan of attack would be to clear out all the media reinstall the Lyra OS from this site: http://www.rcaaudiovideo.com/Cultures/en-US/DownloadsLanding.html then put all the files back on it. If any one has anymore questions email me at Cjsmazda@yahoo.com or just post here so everyone can learn.
| Posted on Saturday, February 12, 2005 - 01:09 pm: |
Recently I bought a Lyra RD2780 and It decode mp3PRO files as regular mp3 ( the "PRO" quality is lost). I am encoding my files with Musicmatch 7.5 software (upgraded) that came with my other Lyra RD1080B player. Any ideas? |
| Posted on Thursday, February 17, 2005 - 03:15 pm: |
the mp3 player will take music and the computer says everthing is functioning normal but when the usb cable is unpluged the mp3 will not read the music, says 0 tracts, any idea whats wrong? |
| Posted on Sunday, February 20, 2005 - 04:57 pm: |
Hi, I have an RCA lyra 2840 that my computer will not recognize when I turn it on. All other functions seem to work fine. I have Windows XP, so I ordinarily would go into "My Computer" and access it as an additional drive (It would show as RCA Lyra. That same drive now shows, but only as "K drive" and disappears when I disconnect the Lyra. I cannot upgrade anything until such time as I can get the computer to recognize it. Any ideas?
| Posted on Wednesday, February 23, 2005 - 09:45 am: |
i have a lyra rd2012b. it plays the first 4 songs from an album, then switches albums. why? |
| Posted on Wednesday, February 23, 2005 - 09:38 pm: |
HELP, I have a lyra 2760. It gets stuck on the RCA screen, the computer doesn't even recognize anything plugged in. I've tryed reset button. RCA support says to send in 60.00 and they will fix it. Anyone know what to do?? |
| Posted on Thursday, March 03, 2005 - 04:07 pm: |
My lyra 2760 is really messed up. I tried to delete all the tracks that i had on it and my computer froze. Then once i restarted my lyra it encountered a profiling error. Now my computer doesnt reconnize it any more in the music match juke box software, on the F: drive in my computer folder or in the lyra upgrade utility downloadable program that i got from http://www.rcaaudiovideo.com/Cultures/en-US/DownloadsLanding.html . Any help would be appreciated. |
| Posted on Saturday, March 12, 2005 - 03:32 pm: |
im wondering if this rca lyra rd2780 can take pictures. if not dont u have a model that is a mp3/digital camera. |
penacka Unregistered guest |
| Posted on Monday, March 14, 2005 - 02:58 pm: |
Hey, I accidently left my RCA LYRA Jukebox in my car for a few hours and it was cold. Now its the next morning and it will not start up. What should i do? |
| Posted on Monday, March 14, 2005 - 09:19 pm: |
How can I get the jukebox to play random music, or continue to play. It stops at each folder, some of the folders only have one song, so it's a pain to have to keep starting over!!! Please help, Thanks |
Daniel_JS Unregistered guest |
| Posted on Monday, March 14, 2005 - 09:44 pm: |
Does anyone know how to display a list of songs WHILE I am playing a song? I would like to return to the menu while a song is playing. Also, I downloaded the latest software version V0.18.1a dated December 2004, but received V0.18.1 , dated Novermber 2004. Any ideas? Thanks. Model - RD2780A Daniel S.
| Posted on Wednesday, March 16, 2005 - 03:30 pm: |
Hi, I have a Lyra jukebox RD2825-Lyra™ Audio/Video Jukebox with 20 GB Hard Drive, High Speed USB 2.0 Connection and Back-lit Multiline LCD Display When I switch it on and it's not connected to the USB and computer, it think it is connected to a computer and says 'do not unplug' and then 'safe to unplug'... only sometimes the computer would recognise it if I drained the battery and started again, I removed all files and reinstalled the most recent firmware but I still get these problems. Any advice would be greatly appreciated  |
| Posted on Wednesday, March 16, 2005 - 03:41 pm: |
I only get sound out of one earphone bud unless i hold the jack in tighter or wiggle it. any way to fix this without returning it? (it's not the earphones either i've tried with 3 pairs) |
| Posted on Friday, March 18, 2005 - 12:06 pm: |
RCA 2840 JukeBox, HD got formatted to NTFS, and it needs to be Fat32. Also, receiving error missing lyra.sys directory or somthing like that. I'm ready to play football with this thing!!!! |
| Posted on Friday, March 18, 2005 - 11:49 pm: |
Ho do I delete songs off of my RCA lyra jukebox RD2780? |
| Posted on Sunday, March 20, 2005 - 09:20 am: |
hello., when i try to record video my lyra comes up with a error and will not record. any way to get around this? any help would be great. p.s. this is my 8 th lyra they are so frigile. DO NOT LEAVE IN A CAR IT WILL DAMAGE THE SOFTWARE email me if you need help i know some stuff about these |
| Posted on Monday, March 21, 2005 - 07:33 pm: |
Anyone know how to open RCA lyra2825 to upgrade HDD to 60 or 80GB? I tried, but after removing the 2 screws on bottom, it still won't open--did not try kick yet! Appreciate any help/links/suggestions! Thanks. |
| Posted on Thursday, March 24, 2005 - 02:29 am: |
UPGRADE YOUR LYRA TO 80GB OR MORE http://www.i-hacked.com/content/view/96/94/ |
| Posted on Sunday, March 27, 2005 - 12:24 am: |
For those of you who are wondering how to record copyrighted dvd and vhs videos i may have found a solution.I personally don't own a lyra but i have 1 on order.I found this post on the circuit city website. "Like the reviewers before me, I too was concerned about not being able to record from my dvd player. I read a review that said you could get past the copyright protection by unplugging the video-in line at the 6 second mark and plugging it back in at 11 seconds. Well guess what..... It WORKS I couldn't believe it but it really does work. So if this was a reason for not buying the RCA Lyra 2780. Don't worry this trick will work." |
| Posted on Monday, March 28, 2005 - 09:20 am: |
HELP! Thang god I actually found this site. Now the question is if someone can help In US for 4 days before I head back to school in Italy. Have Lyra 1090a, can't reach tech support, can't find product manual and can't reset Lyra. Plays the 1st songs in memory but then when it tries to go to the external card it can't read anything and locks. Any ideas? Upgraded the firmware and even reset the card, but can't find a way to reset the whole unit. If anyone knows how to reach RCA tech support that would be great as well. Talk soon -Greg |
| Posted on Wednesday, March 30, 2005 - 07:51 pm: |
Your Lyra: http://www.rcaaudiovideo.com/Cultures/en-US/Downloads.html?ProductID=RD1090 RCA Lyra support: http://www.rcaaudiovideo.com/Cultures/en-US/Support.html RCA Customer Service: http://www.rca.com/customerservice RCA Audio/Video Contact form: http://www.rcaaudiovideo.com/Cultures/en-US/ContactUs.html
Justin schumacher Unregistered guest |
| Posted on Saturday, April 02, 2005 - 03:02 am: |
i have a 2825, and i recently moved to australia, i had to buy a new adapter for it that had variable voltage settings, and the inevitable eventually hapened that a co-workeer plugged it on on a much higher voltage, there was a spark, some smoke and now it wont start, is there a way i can get the info off???
| Posted on Monday, April 04, 2005 - 03:51 pm: |
I have a RCA Lyra 2780 and everything works instead of MP3 Playback. I've reformatted the hard drive and installed the OS and updated it with the latest firmware. My two approaches were ripping a CD in Musicmatchbox and I also purchased and downloaded music from music match box and I still get no functionality. it recoagnizes the file and displays it for about 5 seconds then kicks me back to the main screen. I'm in need of some serious help |
New member Username: Socalhockey72
Rancho Cucamonga,
CA
U.S.A.
Post Number: 1 Registered: Apr-05
| Posted on Tuesday, April 05, 2005 - 04:26 am: |
I also have an RCA Lyra 2780, and I can't get it to play videos from the Windows Media Viewer (wmv files) I've also tried avi files, but no dice. Anyone know what type of file it has to be used in order for the videos to play? Please help!
| Posted on Tuesday, April 05, 2005 - 08:22 am: |
was thinking of purching a RCA RD2780 it would appear one would need this site to make it work and keep it going UK |
| Posted on Monday, April 11, 2005 - 07:03 pm: |
what format are the partion in the 2825A? fat, fat16 , fat32, ntfs? I'm triyng to use it with linux and need to know what kind of partition. Thanks |
| Posted on Tuesday, April 12, 2005 - 12:12 am: |
OK so I got my Lyra and was scared it wouldn't work but it seems to work fine EXCEPT I can't seem to record from TV or VCR. It says "NO VIDEO SIGNAL" but AV cord is plugged in the right way. Any Help? |
| Posted on Tuesday, April 12, 2005 - 04:57 pm: |
hey i was wondering if somebody could help me with my 2780 when i got it everything worked fine but after 3 weeks something happened and the audio was very distorted only with earphones tho i hooked it up to my computer speakers and it sounded great but audio sounds like crap with any ear phones is there anyway to fix this? |
New member Username: Delz
| Posted on Wednesday, April 13, 2005 - 07:29 pm: |
Ok, two things. First, I have a 40 GB Hitachi notebook drive and have heard that it is a fairly simple process to put it into the Lyra. Any comments on that? Second. I have a lot of video that is almost all avi format. Some of the .avi files work perfectly but most are out of synch with the audio when i copy them to the lyra. Is there any way to tell whether they will work properly without having to test them on the Lyra. Also, is there a program that will set up a queue and convert a lot of avi's to mpg overnight? Thanks |
Post Number: 2 Registered: Apr-05
| Posted on Thursday, April 14, 2005 - 01:06 pm: |
Mauro, i believe the formats fat32 Here is link to some info on that: http://www.i-hacked.com/content/view/96/94/ |
| Posted on Sunday, April 17, 2005 - 07:54 pm: |
Hi, my boyfriend is having the same problem with the same model (a 2825) as Justin is. he plugged it into the wrong adaptor, there was a pop and smoke. I thought he was going to cry! is there anyway to fix it? |
camarohair Unregistered guest |
| Posted on Sunday, April 17, 2005 - 11:18 pm: |
My lyra 2760 turns on but is stuck on the loading screen. When I plug in the usb, it says it's transfering data but my computer doesn't recognize it. Can't get ahold of rca cust service, so it's basically become a fancy paper weight. anyone have a suggestion?! |
| Posted on Thursday, April 21, 2005 - 03:43 pm: |
I'm trying to get some tech support too - I have a Lyra MP3Pro RD2012- It worked fine for 3 months now I turn it on and it boots up but turns back off. What's going on? Someone help with this please. This is the first sit eI have found that offers any help at all. RCA tech suppport sux - I can't even find a ph number and this problem isn't even addresed in the manual. Caon you please help?? |
Jwatson Unregistered guest |
| Posted on Saturday, April 23, 2005 - 04:49 pm: |
I have a lyra rd2840. The whole case has swollen and when I turn it on it only plays for a few minutes then turns off, anybody else have this problem? It hasn't been left in any extreme temperatures. |
dktrpuffinstuff Unregistered guest |
| Posted on Sunday, April 24, 2005 - 09:30 pm: |
should i buy a rca lyra from ebay? |
| Posted on Tuesday, April 26, 2005 - 02:25 am: |
I have a RCA Lyra 2780 and i was just wondering if there was anyway that i can get around the copyrighted part on movies and DvDs.( i hope there is cuz scarface is just begging to be put on it) |
| Posted on Wednesday, April 27, 2005 - 12:27 am: |
does anyone know where to find the compolete users guide? if you know, post it, or email me at lsoccergurl21@aol.com. thanx |
New member Username: Roadblock
| Posted on Thursday, April 28, 2005 - 02:47 pm: |
Hi Tech Guy, I was installing new songs on my Lyra. When I unplugged the Lyra from my CPU and restarted it, it suddenly started to make a clanging noise (coming from the HD) and it showed this message "Missing or corrupted system files detected". And when I plug my Lyra to my CPU into USB safe mode, my computer doesn't detect my Lyra anymore, so I can't reformat my Lyra and reinstall it. What can I do to reinstall my software? What have I done to corrupt my system files? Thank you very much for your help John |
| Posted on Sunday, May 01, 2005 - 07:10 pm: |
hello im the proud owner of a ryra av i cant record of the tv,vcr,dvd,kettle? or anything it just comes up with no video signal presant iv tried lots of thing but none of them have worked any help would stop it being smashed by my right foot |
| Posted on Saturday, May 07, 2005 - 08:01 pm: |
I have 2 units of Lyra jukebox RD2840, would like to know what is the way to order the new files I enter in alphabetic order. When is conected to my computer appears with this order, but when It works alone, the new ones are in the last position of the files, and not in alphabetic order. |
| Posted on Sunday, May 08, 2005 - 08:00 pm: |
http://forum.ecoustics.com/cgi-bin/bbs/show.pl?tpc=15118&post=297964#POST297964 Had the exact problem with My Lyra 2760, except now I can see a partial display of HDD INIT FAILED. This occurred after installing musicmatch 10.0 Been to the RCA help site but cannot not load any software because computer does not recognize Lyra. About to switch to MS player & MAC IPOD.... |
| Posted on Monday, May 09, 2005 - 08:15 am: |
howdy, I'm recieving an error: missing lyra.sys file ...a kinda deleted it... accidentally. Where can I get it? I've already tried restoring it from the recycle bin; it doesn't work. PLEASE HELP!!!! |
Paul from TX Unregistered guest |
| Posted on Friday, May 13, 2005 - 11:54 am: |
I have a Lyra 2850. The first time I plugged it into the computer it worked fine. After a few days of use I tried to plug it in again. This time the Add New Hardware Wizard came up and it will not recognize my device. It won't let me install the driver through the wizard because it can't find it on the CD. I have tried to remove all the software and reinstall and it still keeps popping up with the New Hardware Wizard, it recognizes my Lyra as a ?USB DEVICE. Anyone know what I can do to get my computer to recognize it. I run Windows XP |
| Posted on Friday, May 13, 2005 - 01:57 pm: |
i have photos under the photo section of the lyra but they only show up as files and not the actual picture, can anyone help! oh and another thing when i play some videos with the format asf it says (after freezing for 30 secs)fatal error... shutting down please reboot/ oh and one last thing, how can i get the most use out of this wimpy 2 hour charge? tech guy are you out there? |
