Thread: Noob looking for good headphones |
Silver Member Username: Bakerj72
Regina,
Saskatchewan
Post Number: 117 Registered: Jun-05
| Posted on Tuesday, April 11, 2006 - 05:39 pm: |
im more of a car audio guy but i bought some 60$ sony dj headphones a year ago...they broke while travelling. they where great for sound quality. Nowi am thinking of buying another pair.Im thinking about buying a pair of the Sony MDR-V500DJ DJ Swivel Studio Monitor Headphones. if you know of any good headphones available on the internet or w/e that are pretty sterdy(wont break like my last pair) or if i should go ahead and buy those. basically, i just want a pair similar to my old ones, under 100$, and hopefully ones that will last longer than they did. |
Gold Member Username: Illuminator
Post Number: 2849 Registered: Apr-05
| Posted on Tuesday, April 11, 2006 - 07:46 pm: |
The V500's aren't bad, but are mostly built for loudness-which they're excellent at-but don't expect a massive amount of sound quality. Admittedly, the V500 is probably sturdier than what you had, but I've seen all of the nicest (and supposedly strongest built, I mean, they are DJ headphones, and DJ's trash their headphones often) break where the speaker connects to the headband (Technics RP-DH1200, Pioneer HDJ1000, Sennheiser HD280Pro, Sony MDR-V700DJ). Though I would say the V500's are a good choice. They're comfortable and have a pretty good sound. If you want more sound quality, a pair of Grado SR60's would be the best (though you'll look like the telegraph operator on the Titanic). |
Regina,
Saskatchewan
Post Number: 119 Registered: Jun-05
| Posted on Wednesday, April 12, 2006 - 01:24 am: |
haha thx alot... |
Regina,
Saskatchewan
Post Number: 154 Registered: Jun-05
| Posted on Sunday, May 14, 2006 - 02:04 am: |
my old pair was a pair of mdr 350 or 300 and i liked em alot |
Bronze Member Username: Daniel_canada
Post Number: 37 Registered: May-06
| Posted on Tuesday, May 23, 2006 - 04:03 pm: |
The Grado SR60s are excelent, but not good for places like on a plane, they are open type of build. Everyone can hear it. |
