Thread: Initial IDM-850 |
| Posted on Friday, January 06, 2006 - 05:31 am: |
I am after a region free code via for an Initial IDM-850 DVD player bought in the US, thanks. |
Unregistered guest |
| Posted on Monday, January 16, 2006 - 04:32 pm: |
INSTRUCTIONS TO CHANGE THE REGION CODE VIA REMOTE CONTROL FOR INITIAL IDM-850B; 1. POWER ON 2. PRESS ‘SET-UP’ BUTTON 3. SELECT THE ‘PREFERENCES’ MENU (PRESS CENTER ARROW BUTTON THIS IS THE ENTER BUTTON) 4. INPUT THE PASSWORD CODE (2,2,4,4,5,5) 5. PRESS ‘LEFT’ AND ‘DOWN’ BUTTON (NOW THE SCREEN WILL SHOW ‘REGION CODE 1’) 6. PRESS NUMBER BUTTON (2 TO 6) TO CHANGE ZONE. (TRY 10/0 BUTTON FIRST, IF ACCEPTED THEN PRESS SETUP, YOUR PLAYER IS NOW REGION FREE) 7. PRESS ‘SETUP’ BUTTON TO EXIT |
