Thread: Region hack for Accurian portable DVD player APD-3913 |
Carlos-Yanes Unregistered guest |
| Posted on Wednesday, January 04, 2006 - 01:45 pm: |
Does anyone knows how to make the US (Region 1) Accurian portable DVD player APD-3913 (from Radio Shack) region free ?? |
New member Username: Cherryblossom
Post Number: 1 Registered: Oct-06
| Posted on Thursday, October 26, 2006 - 11:41 pm: |
I'm sure you've found out what to do by now but just in case, here's the simple solution: POWER UP the player WITH NO DISK INSIDE. Do not go into any menu. PRESS 9653 on the remote control. This will bring up the region menu. Use arrows to HIGHLIGHT 0. Press ENTER to set to 0. Press SETUP to exit. VOILA! |
New member Username: Edubbconsul
| Posted on Friday, November 03, 2006 - 06:39 pm: |
i need a region code hack for the accurian apd-3298!!!! |
New member Username: Trogovaz
Post Number: 1 Registered: Sep-07
| Posted on Tuesday, September 18, 2007 - 08:07 pm: |
Hi !! I need a region code hack for the Accurian portable DVD player 8" swivel screen Model LMD-6808 (from Radio Shack too). Does anyone know ?? Tks a lot |
New member Username: Bravo2zero
Post Number: 1 Registered: Jan-09
| Posted on Tuesday, January 27, 2009 - 04:03 pm: |
hi!! i need a region code for my accurian portable dvd player 9" wide screen model 16-680 from radio shack.does anyone know?? thanks.... |
