Home > Message Board > Portable Electronics > Cell Phones > Motorola RAZR v3 phone help
Author Thread: Motorola RAZR v3 phone help
Username: Blainew
Post Number: 251
i have verizon and verizon told me that i could buy a razr on ebay and they would activate it any time after the 15 (bc thats when verizons support RAZR) anyways..how many versions of the razr are there...i know there are different colors but are they all the same...ii want to make sure i buy the newest updated one on ebay...any help would be great thank you
Username: Vinnyqh
Portland, OR
Post Number: 85
you have to get the verizon specific razr, the other razrs are GSM and the verizon one is CDMA.
If my phone is on but I do not pick up on an incoming call, I would like to have the incoming call switched to my voice mail. How do I arrange this?
Username: Vinnyqh
Portland, OR
Post Number: 127
If you want it to goto voicemail then when the v3 is closed then tap one of the buttons on the side and it will stop the ringing.
HOW DOES THE VIDEO WORK ! I BEEN TRYING BUT IT WONT RECORD!! HOW CAN I FIX THIS ? HOW DO I GET IT TO WORK?
I have a pink razr and my boyfriend has a black(both on tmobile) and his video will record until u push stop and mine stops after about 5 seconds automatically, is there anyway i can have my pink razr do unlimited recording? Thanks for any help
Lina04
How do I set a ringtone? I downloaded my own ringtones and I see them in the list under "sounds". But I don't know how to set it as my default ring tone. This is for the Razr V3 BTW. Thanks!
I have the RAZOR V3 SILVER BUT IT CAN FILM VIDEOS CNA YOU HELP SO IT CAN FILM VIDEOS
Username: Bass_man
Post Number: 8
to set it as your ring tone, push the center button, then apply as ringtone
Username: Girl4ever
Hamden, America
Ct
hey,i have a pink razr and the internet wont work?..
Username: Tedmac
Post Number: 15
ThanksFree Cell Phones Cellular Phones
Username: Joejimbobgeorge
I have a Razr V3, and I was wondering if there is a way to apply my ringtone to a specific number
Username: Mau
I have Razv3c how can I do to record more 15 secons,How can I do to use like a modem in my cumputer Thanyou every body
Username: Babegrlshorte
Ny
Usa
I just got my razor phone, and I would like to send my pixs that i have taken to my e-mail so i can have them on my computer. I dont know how to do that. Can someone please help me and tell me how. please e-mail me the answer my e-mail is--babegrlshorte@yahoo.com-- thanks so much (i feel so blonde, its prob easy to do)
Username: Orezental
Pompano, Florida
Florida
I got razor and it won't turn on what
Username: Orezental
Pompano, Florida
Florida
if a razor lights turn on but its not on and you can't see the screen what do you do
Username: Orezental
Pompano, Florida
Florida
email me at orezental@yahoo.com if you got the answer i need
Username: Xboyitssochaotic
I just got a new razor from cingular and whenever icall people it, on their phone it comes up as private caller.
how can i fix this?
Username: Monster33
Bethel, CT
United States
How do you change the front screen image on a Razor vc3 by Verizon? You know when is closed I heard you can do this, or is it not possible on the particular phone?
Username: Milla
Edmonton, Alberta
Post Number: 47
how can i unlock my razr
Username: Mohan
Coimbatore, Tamil Nadu
India
Post Number: 11
Hey watch out for Most popular Motorola Mobilephone Models here
Username: 0die
the ear speaker of my razr phone stopped working after i got the outer case changed. is there any way i can fix this?
Username: Lflyddon
I set up a "group" on my Motorola Razor for the people I call the most frequently. But I'm not sure what good a "group" is if you're not able to send a call.
Is there a way to use the menu, select the group & person and then call that person from there (send call). The only 2 options I see for groups are send email and send txt message.
Username: Mpasto01
I have a pink moterola razer from cingular... not sure if this is a razer problem or cingular problem: but 1- every text message i get after 8 message, the first one i received deletes itself.... so i never have more than 8 messages at a time... how can i change this? also, 2- my voicemail doesnt have a password, so anyone can hear my messages just by picking up my phone and calling my VM... how can i set a pw?? thanks!!
Username: Elcheche
Post Number: 56
some body know how ican put games in my motorola v3 racer i connect my phone to my pc but that it can't recongnice or if some body knows some page there i can get for free please letme know thanks for the help
Username: Kissesonly4
i need 2 kno how do u reset the unlock code on my razor phone if u dont remember the old 1 that u had like say i wanna go 2 my text messages and it ask for the password is there any way i can reset it
i need 2 kno how do u reset the unlock code on my razor phone if u dont remember the old 1 that u had like say i wanna go 2 my text messages and it ask for the password is there any way i can reset it}
Username: Naemarie
every time I try to send a text message or store someones phone number my entire phone freezes..I was told that I have a virus on the phone and I can download a anit-virus thing from mcafee but I cant find it. If anyone has any way to help me please email me at xoshortnaexo@hotmail.com
THANKS!!
Username: Gringhuis
I have a Pink Moterola Razor phone and i cant seem to put any music on my phone can you please help me thank you
Username: Keeraismyname
I have the newest 'silver'? MotoRAZR V3xx and it keeps sending my messages as 'pics' messages instead of regular text messages. I know I pushed something while sending a text message because I was startled but I can't for the life of me figure out what I did. Any ideas?
Username: Lyssak007
I have had 3 diffrent friends send me pictures to my cell phone from theres. I saved all three and can see them in the little veiw box but when i go to open them to full size the picture just shows black. Am I saving them wrong? My phone is only 5 days old.. I read the manual and cant find anything. Any tips?
Username: J3d
i have a motorola razr v3.. and i downloaded a couple songs.. but they don't show up anywhere.. unless i go back online, then they're there, telling me that i've downloaded them.. but nothing is to be found.. whats happening?
Username: Igotanewrazr
hey i got the new razr v3 ummmmmmmmmm how do i put music on it with out buying it can i just down load it to the phone like the sliver?
email me and tell me plz
Username: Ustaad_hc
Post Number: 389
just buy motorola tools software and install on desktop then load whatever you want music picture ringtone etc.
Username: Huskerdu88
Boca raton, Fl.
Usa
forgot security code for Razr Vm3 Metro PCS any help here would be KEWL PLZ Help..
-C
Username: Whitecup7
Christmas Day is coming. Here I want to introduce you a very wonderful software. It can help you to enjoy your favourite DVD video movies anywhere and anytime.
Mac Video Converter is a powerful convertor which can convert video files from one format to another format and convert video to audio for Mac OS X users. This mac video converter supports all video popular formats indcluding flv, MPEG1, MPEG2, MP4, 3GP, 3G2, MOV, AVI, Mpeg TS/TP (for HD Video), etc.
Mac Mp4 Video Converter Mac iPhone Video Converter Mac iPod Video Converter
Video Converter for Mac 4Media Video Converter for Mac
Mac Video to AVI Converter
Enjoy your time as you wish.
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Portable Electronics > Cell Phones > Motorola RAZR v3 phone help [ « Previous ] [ Next » ]
