Thread: Headphone for under 150 |
New member Username: Hgihkcin
Post Number: 5 Registered: Sep-05
| Posted on Monday, November 21, 2005 - 10:05 pm: |
what are the best headphones i can get for under 150$ |
Gold Member Username: Illuminator
Post Number: 2255 Registered: Apr-05
| Posted on Tuesday, November 22, 2005 - 12:48 am: |
Personally, I love the Sennheiser HD280PRO's but they have a somewhat laidback sound for some. |
Post Number: 6 Registered: Sep-05
| Posted on Tuesday, November 22, 2005 - 03:12 pm: |
what do you mean by laid back |
Post Number: 2257 Registered: Apr-05
| Posted on Tuesday, November 22, 2005 - 05:03 pm: |
The bass isn't overpowering; they sound very natural and responsive. If you don't mind looks, then I would suggest the Grado SR60's in place of the Senn's. Since you haven't set any parameters other than price, it makes it extremely difficult for anyone to help you find suitable headphones. |
Post Number: 7 Registered: Sep-05
| Posted on Thursday, November 24, 2005 - 12:46 am: |
well i guess the loudest with the best frequency response that doesnt need to be amplified(will be hooking up to an mp3 player) |
New member Username: Audiojoe
Schaumburg,
IL
United States
Post Number: 1 Registered: Dec-05
| Posted on Thursday, December 01, 2005 - 09:18 pm: |
Sennheiser HD485 is also a sound choice for less than $150. VERY comfortable and well balanced sound. It's sounds great with cmoy portable amp and ipod as well as with my home gear. |
