Home > Message Board > Portable Electronics > Headphones > How do i connect the wires on a headp...
Author Thread: How do i connect the wires on a headphone jack???HEEEELP!!
Username: Silentmongoose
hi ppl, I recently bought some headphone jacks, as my old earphones stopped working because of some problems in the jacks(first they cut out every now and then, then eventually they stopped making noise altogether...)
I know theres the red blue(or green?) and copper wires, and there are 3 pieces of metal with holes on the jack. How the hell do i know which ones to connect each wire to. One metal peice is taller than the others by far, with a clamp thing to hold the wire. Then there are two shorter ones, one shorter than the other. Each of these 3 things has a small pinhole in them.
I hope my explanation was clear enough!!! Pleeez can someone help if they have any idea how!!!!Thanx
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Portable Electronics > Headphones > How do i connect the wires on a headp... [ « Previous ] [ Next » ]
