Thread: I need help with my MINI-IPOD: transfering library from one computer to another (PLEASE HELP) |
New member Username: Missleex3
Post Number: 1 Registered: Jun-05
| Posted on Tuesday, June 28, 2005 - 12:16 am: |
hello,, i just got my MINI-IPOD and i've been transfering some songs into it.but the computer ive been using has a problem, and won'tlet me transfer any songs to it. theIpod is functioning perfectly, but when i plug the ipod in it says that there's nothing connected. but it STILL shows the do not disconnect sign! the battery charges, but it just wouldn't let me transfer any songs that i have bought online. i feel like i ahave wasted about 30 dollars on this. well, but i'd REALLY like to know how to transfer songs &your whole library from one computer to anhother. it seems to me like if you switch from one computer to another all your old songs get erased . i actually had to by some songs twice because of that. PLEASE HELP ME!!1 thanks. |
Post Number: 3198 Registered: Dec-03
| Posted on Tuesday, June 28, 2005 - 09:19 am: |
go here http://www.apple.com/support/ipod/ it can deal with most of your concerns |
Post Number: 2 Registered: Jun-05
| Posted on Tuesday, June 28, 2005 - 09:42 am: |
ive already read it but it didnt help much. i connected my ipod to the computer and checked itunes preferences and it says there's no ipod connected, even though the ipod shows the do not disconnect sign! and it won't update any songs, still. |
Post Number: 3204 Registered: Dec-03
| Posted on Tuesday, June 28, 2005 - 10:29 am: |
How are you connected to the PC? And what is your operating system? XP, 98, 2000, me? |
Post Number: 3 Registered: Jun-05
| Posted on Tuesday, June 28, 2005 - 11:51 am: |
the operating system is XP , and i'm connected to the PC with the USB cable that came with my miniipod. it's a laptop, and the USB port is connected, right where it's supposed to be but it still won't import any songs! i BOUGHT the songs and it's in my library in the computer, but it just won't get in the ipod! it doesnt even say 'transfering songs' or anything. |
Post Number: 3206 Registered: Dec-03
| Posted on Tuesday, June 28, 2005 - 12:49 pm: |
Have you tried connecting another device to your USB port? Is it active/enabled? |
Post Number: 4 Registered: Jun-05
| Posted on Tuesday, June 28, 2005 - 01:45 pm: |
yeah. since it's a laptop, i connected the mouse using the USB port and it works perfectly. the ipod is the only thing that's not working. it's connected and charging but the computer doens't recognize it. and i've already installed theCD. |
| Posted on Sunday, July 10, 2005 - 04:25 am: |
it might be the USB port that you're using, I think sometimes, the iPod will only work with USB 2 port... but in any case, try to reboot your iPod.. instruction should be in the manual or on the iPod's website. I had similar problem before and wasted my ONE time tech support on that.. |
rebecca3333 Unregistered guest |
| Posted on Saturday, July 23, 2005 - 03:38 pm: |
I also just got my ipod, and I downloaded some music... it didn't go to my library. It went to one of my files, and won't budge. My ipod says do not disconnect, but the screen says the ipod update is complete. How do I move my music into the library or the my ipod file? |
Linda53 Unregistered guest |
| Posted on Friday, July 29, 2005 - 11:32 pm: |
I just got an iPOD. It shows up under Windows Explorer as G - Removable Disk but it does not show up under iTunes. I have uninstalled and reinstalled the iPOD software and iTunes several times and still have the exact same problem. I am using Windows XP. Any help would be appreciated. |
| Posted on Tuesday, August 02, 2005 - 09:56 pm: |
I recently had to restore my computer. How do I get my songs from my ipod mini back on my computer? HELP! |
| Posted on Friday, August 05, 2005 - 12:22 pm: |
I just got my ipod mini and I've been trying to download this one CD to my ipod. iTunes says its downloading the songs to my ipod, but when I look for the songs on my ipod nothings there. What should I do? |
Courtney Unregistered guest |
| Posted on Friday, August 12, 2005 - 07:16 pm: |
WELL, i got my ipod yestarday. i come home. and start to do it. i do the whole cd set up stuff and it only says its "charging" i downloaded stuff onto itunes from my own personal cds. it has twenty-five songs on itunes now, but it wont go to the ipod.all it says is "charging" do u think something could be wrong with the USB? or should i return my beloved ipod... p.s. its a mini |
courtney Unregistered guest |
| Posted on Friday, August 12, 2005 - 07:27 pm: |
it was the USB ports haha thanks anyway |
p2p1992 Unregistered guest |
| Posted on Friday, August 12, 2005 - 10:09 pm: |
i had gotten some music from my sisters house and put it on my ipod mini now i am at a nw computer HOW DO I TRANSFER MUSIC FROM MY IPOD TO THE COMPUTER?????????????? |
miniipodproblemfixermaybe Unregistered guest |
| Posted on Friday, August 19, 2005 - 04:29 am: |
HOW TO FIX THE ANNOYING PROBLEM:!!!!! *i had an ipod mini that when i connected it said "do not disconnect"... when i finally shut my computer off... that messaged went away... i thought music would be automatically-transfered to my ipod but it wasn't!!!! *you need to have an "icon of your ipod" located in the list on the side of the itune window. if it isn't.....then it won't copy your songs!!!! **this is what i did...*** *restart computer and unplug your mini, then when your computer is started up again, open itunes, and then when the window is open, plug in your mini... if the "update window"opens then click **restore** (i lot of ipods need to update/restore to work right!!!)... then restart computer again, and unplug ipod... keep inserting ipod when you open the itunes window... do this a few time (restarting comp...) and "eventually" you'll see the "little ipod icon" located in the itunes list (on the right) and then it will start transferring songs.... *this mini ipod pissed me off so much but once you get that "ipod icon" in the list then it will automatically start loading songs to ipod!!!! *i hope this helps any1 who is pissed off with the mini-ipod big complication! go to apple help and watch little video for ideas to fix prob. |
| Posted on Saturday, August 20, 2005 - 12:31 pm: |
I downloaded music from a friends computer on to my IPOD. I transferred them all to my PC. But now when I try to make new playlists, my ipod says that it's full!! It will only take 26 songs. HELP |
| Posted on Tuesday, August 23, 2005 - 07:31 am: |
i got the same problem my computer detects my i pod but i tunes doesnt ..so that i cant transfer any music to my ipod..pls HELP ME |
Jengerbil89 Unregistered guest |
| Posted on Wednesday, August 24, 2005 - 06:53 am: |
I bought an iPod Mini last night, managed to put some songs on it at my dads, then brought it home. It is connected to the computer, and it says do not disconnect, but according to the Apple site the music should automatically transfer over to my pod. But its not. Ocasionally the ipod icon appears in the source list on i-tunes, but it wont let me copy the music onto the pod. My sister has got one and has never had this problem. any ideas? Jen x
Post Number: 3492 Registered: Dec-03
| Posted on Wednesday, August 24, 2005 - 07:13 am: |
Because you conected to 2 different computers, that usually causes a problem. Go to the apple website and do a search on using mulitple computers for 1 iPod. |
| Posted on Thursday, August 25, 2005 - 12:11 pm: |
ok heres one for ya, a friend transfered songs to my mini ipod from her computer, how do i transfer the songs from my mini ipod to my library, on my computer? |
Post Number: 3538 Registered: Dec-03
| Posted on Thursday, August 25, 2005 - 12:58 pm: |
you can't it is a one way transfer. You must know how to turn your iPod into a removable hard drive. Go to apple.com and do a search on the tech support under hard drive. |
Post Number: 3539 Registered: Dec-03
| Posted on Thursday, August 25, 2005 - 12:59 pm: |
iPod made it a one way transfer to keep people from doing what you are doing. |
| Posted on Saturday, August 27, 2005 - 03:02 pm: |
| Posted on Saturday, August 27, 2005 - 03:36 pm: |
wen i connect my ipod into my computer my computer detects the i pod but when i go to i tunes it say no ipod connected ..help me pls !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! |
| Posted on Tuesday, August 30, 2005 - 04:26 pm: |
i had my computer fixed and had to erase everything including itunes. all my songs are erased and i dont want to go through the trouble of downloading all 295 songs again. is there any way i can transfer the songs on my ipod mini to my computer?? please respond- |
Post Number: 3687 Registered: Dec-03
| Posted on Tuesday, August 30, 2005 - 04:53 pm: |
NO. Read the above posts...it is a one way transfer only! If you want to do that you need to hack your iPod. Do a search on iPod hacks, there is also a program that can extract that info from your iPod, but I don't know what it is.
| Posted on Wednesday, August 31, 2005 - 01:20 pm: |
My ipod software was loaded on to a friends computer as I didn't have one when I bought my ipod. I have since bought a laptop of my very own and want to get my tunes from her computer onto mine. I had to take my ipod into the store to get it checked out and they plugged it in and wiped off over 3000 songs. Obviously I don't want to have to do it all again. I've downloaded the i-tunes onto my computer from the internet but I don't have the CD that came with the ipod, it has mysteriously disappeared so how do I get round this problem. Urgent help would be appreciated as I go on holiday for a week and will be pulling my hair out with no music. Thanks. |
Post Number: 3708 Registered: Dec-03
| Posted on Wednesday, August 31, 2005 - 02:02 pm: |
Barbie, You need to get the music from your friend's computer and wwrite it on to a disk or other removable media. Transfer that music on to your pc and from there add it to your iTunes library. Then you can put it in your iPod. You can also use the iPod as a hard disk drive but it would be complicated so we'll keep it simple Unless of course you already know how. If your iPod software was loaded on to a friends pc, it would probably be with your friend. |
| Posted on Thursday, September 01, 2005 - 01:02 pm: |
My sister and I both have Ipods on the same computer. Is it possible to get two different accounts on the computer so that we can both have our own music on each account instead of all on one account? If so I would be very grateful for help on how to accomplish this! |
| Posted on Saturday, September 03, 2005 - 06:00 pm: |
my ipod used to work fine until one day i tried to recharge it and when i plug it in the USB port , nothing shows up on the ipod , just plain screen and its like my USB port doesnt work, any suggestions? did anyone have the same problem? |
| Posted on Saturday, September 03, 2005 - 06:02 pm: |
i cant even update songs because its like the iPod isnt connected to the computer even if it is connected to the USB port |
isabella Unregistered guest |
| Posted on Saturday, September 03, 2005 - 08:56 pm: |
i just got an ipod, and i just wanted to know how you transfer cds to my ipod? can anyone help?? |
Post Number: 3778 Registered: Dec-03
| Posted on Saturday, September 03, 2005 - 11:23 pm: |
Isabella, Use iTune to import the songs from your CD to the iTunes Library. Fromt eh library you drag and drop into the iPod icon on your iTunes window. |
| Posted on Sunday, September 04, 2005 - 04:57 pm: |
I have had a 20GB ipod for about 8 mos. now. in may my original PC that i had my ipod working with crashed on me. since then i've switched to Mac. however, now i can't use my ipod with my mac without reformmating my ipod and erasing all 5000 songs on it. i don't really want to do that because that's a buttload of cds that i'd have to upload again on to my computer and that's just a heck of a lot of time (about 150 cds i think). also i'd lose some other music just from friends' cds that i have ripped onto the ipod (so i don't have hard copies of every cd basically). i'd like to know if there is a way that i can convert my ipod library to my mac or atleast format it for my mac without having to go through the labor of re-importing my entire cd collection again. that sucks. please help me out if that can be done. thanks! Dan |
Post Number: 3790 Registered: Dec-03
| Posted on Sunday, September 04, 2005 - 07:13 pm: |
I'm afraid not. Apple is making it difficult to do that so people don't do the file sharing mess again. If we want our music on our iPod we have to work hard to transfer it. I know it sucks! |
| Posted on Monday, September 05, 2005 - 06:47 am: |
i have 60g photo n its all hooked up rite n everything works perfect except its doesnt transfer from itunes to ipod. the music is all in the library ready to go, the ipod is disconnected until the comp is turned on, when itunes starts up n the ipod is connected it automatically starts updating, the problem, it suddenly stops updating, doesnt say anything n hasnt transferred anything. It transferred once but wont again. i have rebooted the comp a few times n nothing has worked. what do i do? this is really frustrating... |
Janayto Unregistered guest |
| Posted on Thursday, September 08, 2005 - 09:32 am: |
I want to transfer my songs from my ipod to my library! My computer got cleaned out so all my files are gone! how do i get them to the library? |
Post Number: 3876 Registered: Dec-03
| Posted on Friday, September 09, 2005 - 04:48 am: |
george18, check your preferences and see if the iPod transfer is checked of as "manage my songs manually" or "automatic". If it is manuall, you have to specify which songs are going to transfer. If it is automatic, all the songs that are checked on you itunes will be transferred everytime you dock your iPod. |
Post Number: 3877 Registered: Dec-03
| Posted on Friday, September 09, 2005 - 04:49 am: |
janayto, You cannot transfer music files from your iPod to your computer.If you find a work around post it here,but that is the way it was coded. |
jennyhenry86 Unregistered guest |
| Posted on Saturday, September 10, 2005 - 10:13 am: |
I have just bought an ipod mini, and want to transfer all my songs from my pc (Windows XP) onto it. However, a lot of the songs are ones I ripped from CD into Windows Media Player, and don't show up in itunes. My brother said it was something to do with the type of file they are. Could anyone give me any advice on how to get ripped songs from Windows Media Player onto my ipod, without having to do it all again by ripping the CDs into itunes? (The songs I've actually downloaded from the internet can all be imported fine) |
Post Number: 3914 Registered: Dec-03
| Posted on Saturday, September 10, 2005 - 05:37 pm: |
Find out where the music files are stored and use the "add folders to library" on your iTunes. From there the iTunes will convert your WMA files to the files that can be used by your iPod. |
| Posted on Sunday, September 11, 2005 - 09:58 pm: |
i upgraded my itunes to 5, and when i did that it deleted all my songs on itunes. i tried to find my files but their all "damaged" supposedly. Is their any way i can import all my songs from my ipod into my library? |
| Posted on Sunday, September 11, 2005 - 10:23 pm: |
I upgraded my itunes to 5 and it said all my songs were damaged. Do now i dont have any songs on my itunes. i tried to pull them up from a file but they are supposedly damaged. is their any possible way i can import my songs from my ipod onto my itunes library |
Post Number: 3949 Registered: Dec-03
| Posted on Monday, September 12, 2005 - 06:04 am: |
no you need a hack, just google it |
| Posted on Monday, September 12, 2005 - 06:40 pm: |
hack? what do you mean? |
Post Number: 3963 Registered: Dec-03
| Posted on Monday, September 12, 2005 - 11:55 pm: |
Forget it. It is only a one way transfer, you cannot transfer music from your iPod to your computer or to any other computer, unless you are using the ipod as a removable hard drive. I doubt that you know how to do that, so you are stuck with the music on your iPod. If you don't know what a hack means you won't know what it can do and you probably wouldn't know how to apply it. Sorry to be so blunt but leave it to someone who knows what they are doing. |
| Posted on Tuesday, September 13, 2005 - 07:56 am: |
ya, all you had to say was take it to a professional. no need to be rude. |
Post Number: 3984 Registered: Dec-03
| Posted on Wednesday, September 14, 2005 - 04:57 am: |
Yup, take it to a professional. I was just being truthful, if you can't handle it too bad. Your anonymity should give you a modicum of self indulged protection so don't feel too slighted. Relax. That information is in your instruction manual, all you have to do is read it. Then there is tech support. |
| Posted on Friday, September 16, 2005 - 09:13 pm: |
ok i have a ipod mini! omg! i turned on muh ipod and a picture of a ipod with Xs for eyes and a sad face came up.den a picture of a battery wit little power? Wuts happening? Can it be fixed? i DIDNT FROP IT OR ANYTHING! PLEZZZZZZZEEEEEEE HELP ASAP! I CANT LIVE WITHOUT MUH IPOD! |
Post Number: 4011 Registered: Dec-03
| Posted on Friday, September 16, 2005 - 10:34 pm: |
Your iPod is dead. Nothing you can do but send it in for repair or buy a new one. |
| Posted on Wednesday, September 21, 2005 - 12:49 am: |
Hi..i just got my IPOD and i downloaded all the itunes software..All the songs that i already had on my computer automatically went directly onto my ipod....but when i put a new cd in the computer i cant figure out how to make it go onto the IPOD....? I read the IPOD(mini) booklet thing and it says it will automatically but the new songs onto it once you hook it up with the USB wire but it doesnt do it...? Help please... |
kristen_m Unregistered guest |
| Posted on Thursday, September 22, 2005 - 09:00 am: |
i got exact same prob. had ipod for 3 months works fines, but now it charges but the 'do not disconnect sign' doesnt even come up and i cant put new music on there.... |
| Posted on Saturday, September 24, 2005 - 11:30 am: |
I want to know if you can download music without using the itune disc |
Post Number: 4051 Registered: Dec-03
| Posted on Saturday, September 24, 2005 - 07:19 pm: |
Brenda, Do you mean download music to your iPod? |
AnaVill Unregistered guest |
| Posted on Monday, September 26, 2005 - 07:34 pm: |
HI, When I play my mini ipod it skips a lot of songs and the volume can´t be controlled from my Ipod I have to use the Car stereo volume. Do you think this is caused by using both MAc and PC to transfer songs?? First I used a Pc to transfer the songs from my itunes to my ipod. Then I used a Mac to transfer songs, without formatting. Thanks in advance |
anavill Unregistered guest |
| Posted on Tuesday, September 27, 2005 - 10:41 am: |
I found that there is a way to transfer all your Ipod music library to your Itunes. Look up for a software called "Copypod" CopyPod is the ultimate backup & recovery tool for your iPod. It enables to easily transfer your iPod's music library to your PC without loosing ratings and playlists and other personal data. Being able to download music from your iPod is useful whether you need to send your iPod for repair, retrieve your music because of a computer / hard drive crash, or just to backup to a different drive, CopyPod will get your music off your iPod effortlessly.
| Posted on Tuesday, September 27, 2005 - 02:08 pm: |
my computer detects my ipod mini. but itunes doesnt. My ipod is charging but no songs are downloading onto it. So now i am left wit old songs !!!!! please help. iv tried restoring my ipod but it isnt detecting it. Iv also tried plugging my ipod in my other usb socket. But it just isnt working !!! |
theodore Unregistered guest |
| Posted on Tuesday, September 27, 2005 - 03:36 pm: |
hey berny is it that complicated to use your ipod as an external hardrive? can you just open it up in my computer and then just drag your files onto it like saving it on a disk or thumbdrive? or is it way to complicated to explain? thanks |
unknown member Unregistered guest |
| Posted on Wednesday, September 28, 2005 - 02:25 pm: |
my ipod did that thingy were itunes does not detect it. but i left it for 24hrs tried it again and it worked!!! i was landed. i hope this was a help to anyonw who was having that problem. |
ahgibbs Unregistered guest |
| Posted on Thursday, September 29, 2005 - 03:58 am: |
Im looking at buying an ipod but everyone I talk to tells me different stuff. At the moment all music stored on my computer is accessible through either Windows Media Player, or Real Player and majority of the tracks are .wmp files. From what Ive heard, does this mean I wont be able to transfer any of these onto an ipod or can I convert them? Its just I have hundreds of tracks and itd cost a fortune to replace them all! |
Miscellaneous Unregistered guest |
| Posted on Thursday, September 29, 2005 - 04:02 am: |
Excellent deals on ipods here http://ipods.freepay.com/?r=22969251
Post Number: 4067 Registered: Dec-03
| Posted on Thursday, September 29, 2005 - 06:52 am: |
theodore, no it is not that complicated. When you open up "my computer" it will show up as an external hard drive. If you want detailed instructions go to the apple.com website. |
Post Number: 4070 Registered: Dec-03
| Posted on Thursday, September 29, 2005 - 07:00 am: |
ahgibbs, yes you can download those songs to your ipod. iTunes can convert them to load into your library and into your iPod. |
| Posted on Thursday, September 29, 2005 - 08:20 am: |
Will it do that automatically or will I need to get some additional software to do it 4 me? |
Anony-fu%$#-mous Unregistered guest |
| Posted on Friday, September 30, 2005 - 12:52 pm: |
This might help some people. Just remember that every ipod comes with a one year warranty. Just go to www.apple/support/ipod.com if you bought it trough the e-net. And fill out a small application with your info and what's wrong with the ipod, even if its Bull $h!#t. They'll send a small box which you'll fit the ipod in. It comes with istructions, and a 1-800 # where you can schedual a free pickup. It's a very easy process, and you'll get a brand new ipod with-in a week, I'm on my 3rd, so go get those A holes which come out with new color ipods right when you buy a color-less or not the stylish nano which is better than the mini, AT THE SAME COST!!! Sincerely, one pissed off but satisfied apple customer. |
Gold Member Username: Illuminator
Post Number: 1830 Registered: Apr-05
| Posted on Friday, September 30, 2005 - 02:28 pm: |
That's...unethical. |
L. Davis Unregistered guest |
| Posted on Friday, September 30, 2005 - 03:54 pm: |
Hi, I have a question.. I just bought an iPod mini, it will be delivered in about 5 days. I have about 500 songs already saved onto my PC, all in mp3 format. How would I go about transferring those songs from my desktop to my iPod mini? Thanks. |
Post Number: 4078 Registered: Dec-03
| Posted on Sunday, October 02, 2005 - 02:59 am: |
ahgibbs, once you add the songs to your library, iTunes will automatically conver it for you so it can be loaded on the iPod. |
super_ally Unregistered guest |
| Posted on Sunday, October 02, 2005 - 02:34 pm: |
arrghhh please help! this problem has come up a lot but cant really find an answer..plugged my mini iPod into a different computer and it wiped all my music and im just left with her music and now my computer doesnt recognise my ipod. plz help..many thanks  |
Post Number: 1863 Registered: Apr-05
| Posted on Sunday, October 02, 2005 - 02:40 pm: |
Yeah, you weren't really supposed to switch computers... |
| Posted on Tuesday, October 04, 2005 - 11:16 am: |
welll duh its in the rule book dint u check it out ? |
laura4008 Unregistered guest |
| Posted on Sunday, October 09, 2005 - 07:54 am: |
hi i really need some help and advice on my i pod mini. i have windows ME and know thats its not compatiable with the ipod. ive tried loading the cd (which wont work) and plugged the ipod in to charge and to see if there was anyway i could get around it but now on my ipod it has a little folder sign with "www.apple.com/support". ive been on to the website but find it very confusing!!! ive tried switching it off pressing hold, basically trying everything that involves the ipod and computer!!! now at this present time its just frozen!!!! is there any way i can get round this? please help!!!! |
| Posted on Wednesday, October 19, 2005 - 03:18 am: |
http://www.engadget.com/ check out this site......... it helps u tranfer ur songs from IPod to your PC'S......... its real good!!!! |
Nat Comp Geek Unregistered guest |
| Posted on Wednesday, October 19, 2005 - 09:42 pm: |
Everyone who wants to have their friends Ipod music and their music at the same time on the same Ipod is gonna love me to death!!! Like everyone else I wanted to have Sydney's(friend)ipod on mine at the same time as having my own. I didn't want any viruses either. I looked all over and I found this site that lets you download this software called SharePod. It downloads it onto your Ipod and you can upload your music from your Ipod. here is the site http://sturm.t35.com/sharepod/index.htm If you have any trouble with it then type back and let me know, but i doubt you will! |
| Posted on Saturday, October 22, 2005 - 11:01 pm: |
how do i get phone number for phone help for new ipod? |
| Posted on Saturday, October 29, 2005 - 09:06 pm: |
my boyfriend and i use the same computer and both have ipods can we both set up our own accounts were his music wont transfer on to my ipod thanks teresa |
unsatisfied customer ALREADY Unregistered guest |
| Posted on Saturday, November 05, 2005 - 05:28 pm: |
ok i just bought an ipod 30GB last night and i put in the cd it gave me to setup the itunes program...all my music already on my computer was transferred into the library and i've tried putting some songs on my ipod through the songs i have in my library and the cds i put in my drive...but its not friggin working..what the hell am i supposed to do? apple didnt give me a detailed instructions booklet so wtf am i supposed to do? am i gunna ave to return this peice of shiit already?? please someone help me before i sue....sorry im just really annoyed and frustrated..thought this was supposed to be easy since i paid a lousy $400 on this fukkin shiit!!! grrrr!!! |
| Posted on Friday, November 11, 2005 - 01:23 pm: |
How do i my music on to the ipod |
| Posted on Monday, November 14, 2005 - 03:40 am: |
itunes problem. I've downloaded the Desperate Housewives Video "I Wish I Could Forget About You". It took about 30min to download (which seemed odd) and then never showed up on my purchased or video list, but it charged me for it. Any ideas how this happened or how i can get my video? |
brean flemings Unregistered guest |
| Posted on Wednesday, December 07, 2005 - 08:44 pm: |
I Have a mini and i have dropped it on the ground and it want turn on can someone help? |
| Posted on Saturday, December 10, 2005 - 02:07 pm: |
my ipod doesn't show that i have songs on it and my computer won't show my list of songs but at the bottom of the screen it does acknownlegde 3.00gb used out of 3.76gb how do i get my ipod to download the songs back onto my computer |
| Posted on Saturday, December 10, 2005 - 03:13 pm: |
^ is there a way to fix this problem |
| Posted on Thursday, December 22, 2005 - 03:00 pm: |
Is there anyway you can install your Ipod mini onto the PC without using the installation cd that came with it? |
Cathal, UK Unregistered guest |
| Posted on Thursday, December 29, 2005 - 07:47 am: |
Guys, while copying from your ipod to PC is not supported by itunes, there is loads of software that will do this, such as copypod, sharepod and more. These (the ones I've come across at any rate) seem to have been written by ipod using programmers who were irritated about the limitations of itunes - i.e. not by a load of evil spyware peddling scumbags. Anyway, there is a useful article about this in About.com: http://macs.about.com/od/ipod/a/copy_from_ipod.htm Hope you find this useful. |
*!X!*Hannah*!X!* Unregistered guest |
| Posted on Friday, December 30, 2005 - 12:44 am: |
okay, so i have an ipod mini, and, like, i connect it and it charges, but my computer never says that its connected. i put songs on my itunes, but it never goes on my ipod! im wondering whats going on because the songs i try to put on there are really awesome and im sad because its not working! PLEASE HELP! |
| Posted on Saturday, December 31, 2005 - 12:37 pm: |
i got music off of my sisters computer onto my ipod. but now im on my own computer and i want the songs already on my ipod to be in my library as well. how do i get them there? please help. if you know the answere email it to me at br0k3n_sm1Le_x3@yahoo.com .. thanx |
| Posted on Tuesday, February 07, 2006 - 07:46 pm: |
Ok i bought an i pod off of my friend and they had about 400 songs already on it. When i went to go add some cds it totally erased every song that was previoulsy downloaded, so then my other friend took it for me and added songs..i want to add more cds but i dont want all the other ones erased again..soo what do i do? thanks a bunch |
BaDKiTTy Unregistered guest |
| Posted on Tuesday, February 28, 2006 - 11:46 pm: |
you can transfer you songs from ipod to your computer. before installing itunes plug ur ipod to usb and just copy ur songs from removeble disk to you hard drive. then install ur itunes again adn load ur song to ur library. im doing this right now actually. good luck ppl. |
New member Username: Dallasjam
Post Number: 2 Registered: Apr-06
| Posted on Monday, April 24, 2006 - 05:46 pm: |
Berny, I am having the same problem as Linda53. What do you suggest? |
