Thread: My apex dvd player play great for years,now when you put a dvd in its said no disc,i have clean disc and dvd ,whats the problem |
Unregistered guest |
| Posted on Thursday, June 23, 2005 - 08:07 am: |
i never had no problem ,just keeps saying no disc,i have clean it and dvd |
luke117 Unregistered guest |
| Posted on Saturday, July 23, 2005 - 12:58 am: |
Exact same problem...apex dvd player as well... |
New member Username: Daveyjones
Melbourne,
Florida
Usa
Post Number: 1 Registered: Jul-05
| Posted on Saturday, July 23, 2005 - 04:14 pm: |
My dvd now says...disk is valid.....nothing works |
cyberdork Unregistered guest |
| Posted on Sunday, July 24, 2005 - 05:05 pm: |
I know this sounds strange but you may want to pop the dvd in then turn the player on its side or upside down. I had a problem with losing the color and I did what I suggest and it worked. I figured I had nothing to lose.
marty from Georgia Unregistered guest |
| Posted on Sunday, August 14, 2005 - 08:16 pm: |
I am having the No Disc problem. I tried the turning solution with no improvment. |
Debi from Kankakee Unregistered guest |
| Posted on Tuesday, September 27, 2005 - 01:29 pm: |
I have the same problem with my personal Apex DVD player. It plays cd's fine. If anyone has other suggestions... |
Wilbur 77 Unregistered guest |
| Posted on Monday, December 19, 2005 - 06:33 pm: |
Do a search on Apex 1200 repair, I found a site a while back and have successfully opened and stretched 4 springs that the main body rests on. I don't know what model you have but there is a good chance that they are very similar inside. |
| Posted on Monday, December 19, 2005 - 09:07 pm: |
I need help! My daughter spilled a drink in the vehicle and it went inside the DVD player - can it be fixed or is it ruined and where do I go to get this information? |
