Thread: Help how do you reformat napa mp3 players???? |
| Posted on Tuesday, June 21, 2005 - 06:02 am: |
everytime i go to listen to my mp3 player it keeps telling me: incorrect format please reformat the player!! How do i do that? |
Unregistered guest |
| Posted on Tuesday, July 05, 2005 - 06:18 am: |
my mp3 player keeps telling me to reformat my mp3 playerhow do i do this ? |
| Posted on Tuesday, July 19, 2005 - 04:02 pm: |
How do I reformat my Napa MP3 device from Windows Media 9 to the 10 version as my new computer only will install 10 |
| Posted on Friday, July 22, 2005 - 02:06 am: |
Folks if your NAPA 1 GB LCD MP3 player is showing "incorrect format please reformat the player" then install the software which came with the Mp3 player and run download firmware while doing so there is an option to Format data area select that and run it. |
| Posted on Tuesday, August 02, 2005 - 08:12 pm: |
I have a NAPA 1Gb LCD MP3 player but with a Windows Me operating system there is no "Safely Remove Hardware " icon beside the clock as suggested in the user manual. Hence I'm reluctant to remove the MP3 player until I know it is safe to do so. Can you help ? |
| Posted on Wednesday, August 10, 2005 - 07:30 am: |
my napa mp3 keeps telling me reformat it but how do i do it |
| Posted on Thursday, August 18, 2005 - 05:27 am: |
my NAPA mp3 player says incorrect format plez reformat player evrytym i want 2 play sumthin and wen itry reformat using windows a msg apperars that windows is unable 2 complet reformat pleeez help.how do i get it2 work again |
JoseLopez Unregistered guest |
| Posted on Thursday, August 18, 2005 - 07:00 pm: |
Hi guys, i too have been having troubles with my napa 256mb mp3 player. It has stopped turning on and off when i try to, but is content with turning on at it's own accord. Does neone know what to do? (have allready tried banging it!) |
| Posted on Sunday, August 28, 2005 - 04:42 pm: |
has ne1 found owt how 2 reformat an mp3 player yet? |
| Posted on Wednesday, September 07, 2005 - 05:10 pm: |
Argh mine does that please reformat player thing but I can't find any of the software as my mum installed the player on her computer and I don't know where she has put the CD. Is there any other way I can do it? |
| Posted on Wednesday, September 07, 2005 - 05:12 pm: |
| Posted on Thursday, September 08, 2005 - 04:47 pm: |
everytime i go to use my mp3 player it comes up incorrect format, when i go to correct the formatt my pc says formattind could not be completed. please tell m e why this is. |
jennie the jen Unregistered guest |
| Posted on Saturday, September 10, 2005 - 05:53 pm: |
Same here guys O__o |
| Posted on Monday, September 19, 2005 - 12:28 pm: |
when i got to listen to my mp3 player it says : incorect format please reformat the player! How do i reformat it? |
| Posted on Monday, September 19, 2005 - 12:34 pm: |
when i go to listen to my mp3 player it says: incorrect format please reformat the player! how do i reformat it? |
yjvkuyg Unregistered guest |
| Posted on Monday, September 19, 2005 - 02:32 pm: |
insert the CD to bring up the menu, select "view manual" to bring up Adobe help file and go down to where it says "click here to install mp3 playerdriver" under Installing Mp3 Player. then goto Start>Programs>Sigmatel MSCN Audio Player>Firmware download. Select the Download Options > Format Data Area tick box and click on Start. I couldnt do it through the Setup Driver option but it did work when i did it through the help file in Adobe, dunno why. hope this helps u guys, its taken me all afternoon to do it. |
Napa1Gig Unregistered guest |
| Posted on Wednesday, September 21, 2005 - 02:22 pm: |
This place was really helpful with my problems: http://www.compuforums.info/ |
Shavkat Unregistered guest |
| Posted on Thursday, September 22, 2005 - 06:52 am: |
For those whose player gives an error message like "incorrect format reformat your player Download a firmware/formating tool form http://service.packardbell.com/ or www.pachardbell.com Format your player with this tool choose "Format data area" and you are done! I am using Pachard Bell AudioKey and I also had a problem like this today I did the above mentioned procedure and now I am listening to my player |
philip1977 Unregistered guest |
| Posted on Saturday, September 24, 2005 - 02:53 pm: |
Is their any way that you can skip from album to album rather than skipping fron track to track? |
annonamous Unregistered guest |
| Posted on Sunday, September 25, 2005 - 01:01 pm: |
can i ask Shavkat where he/she went after they got into the website because i can't finf the "format data area" cause my mp3 is showing that exact reading...so please tell...:D thanks |
danimgay Unregistered guest |
| Posted on Monday, September 26, 2005 - 05:36 pm: |
im a spasdik |
| Posted on Thursday, October 06, 2005 - 02:48 pm: |
I have a NAPA 512MB LCD MP3, i accidentally formated it & deleted all my songs. i have windows XP. when it was formated it still stayed as format FAT32, i also used the disc that came with it to make sure it was right. But now when i load songs onto it, they won't play, just skip the seconds. Please Help! |
| Posted on Friday, October 07, 2005 - 11:01 am: |
does anyone know where i can download music for my NAPA 1gb mp3 player easily and legally? I dont mind paying for the tracks |
| Posted on Sunday, October 09, 2005 - 01:35 pm: |
i have SIGMATEL 3500 chip This player dont run with USB power I have to tun it on Battery Firmware VER is 2.521 Is there any way to run it as a player when it is connected to pc It can only b used as drive when connected to pc |
| Posted on Wednesday, October 12, 2005 - 10:08 am: |
Hi there, I keep downloading music onto the NAPA player which is states is successfully complete, but when I remove the USB and press play it tells me there's NO FILES, even though the windows player states that the sychronisation is complete and I see the downloading occuring on the screen. Any clues? |
sweety pie Unregistered guest |
| Posted on Sunday, October 16, 2005 - 12:44 pm: |
what do you do when a NAPA MP3 Player strts to say "incorrect format reformat the player" |
| Posted on Sunday, October 23, 2005 - 04:03 pm: |
what do you do wen a napa mp3 player keeps saying 'incorrect format reformat the player some 1 plzz help? |
napaproblem Unregistered guest |
| Posted on Monday, October 31, 2005 - 08:58 am: |
i have a 1GB napa pm3 player. i dont know whats wrong with it,it doesnt turn on at all. its now only a memory stick nomore mp3 player. i press the turn on button and the blue screen comes on for 2 seconds and then turns off, please help anyone highly appreciated |
| Posted on Sunday, November 13, 2005 - 11:36 am: |
I was just given an napa 1gb mp3 player with voice recording, however it only lets me use half of the available memory. half the space on it is free/empty, how do i get more songs to load like they are supposed too???? |
| Posted on Monday, November 21, 2005 - 11:11 am: |
Do u have big saggy sausage tits? i do, do you, i do, do you |
grotbitf Unregistered guest |
| Posted on Tuesday, December 13, 2005 - 05:08 pm: |
Thanks Shavkat!! I downloaded Packard Bell's patch from the MP3 site (once installed it doesn't do anything until the computer detects the MP3 player -see below). Then I followed the instructions for re-setting the MP3 player (remove from PC - remove battery - press play and insert into USB port - keep play pressed for >5 seconds). The computer recognised a new USB device and ran the PB patch from within the installation wizard. I fouled up here and tried to format the new drive using Windows XP - don't do this, I had to start again!. After new USB device recognised ran Firmware Download as described by poster named "yjvkuyg" (see above). Hey presto! got my tunes back! |
| Posted on Wednesday, December 14, 2005 - 05:06 pm: |
my mp3 player keeps telling me to reformat my mp3 player how do i do this ? |
| Posted on Saturday, December 24, 2005 - 10:37 am: |
hai this is ragu my napa usb keep telling that incorrect format please reformat some please help me |
| Posted on Tuesday, January 03, 2006 - 03:59 am: |
mine just flashes on and off i have reformatted it several times and the same thing keeps on happening, any ideas???? |
| Posted on Wednesday, January 04, 2006 - 04:25 pm: |
Any Problems With Napa MP3 Players The Following Should Sort It: 1) Run the CD that came with it and install the drivers even if u have winodws xp. Eject the cd once drivers installed 2)Connect your mp3 as normal 2) Now open the following: (its a good idea to be connected to the internet so it can upgrade suitable firmware for your mp3 at this stage) start>all programs>SigmaTEL MSCN Audio Player>Firmware Download 3)If you want to upgrade the firmware just click start then wait. If your having storage problems such as the "file cannot be created" error messafe or not all songs are being played/displayed/stored propperly tick format data area. (p.s make sure you backup data already on the player as all files on it will be erased at after clicking start) 4) Click 'Start' and wait until it finishes. This method should sort out most of your players problems its a good idea 2 do this roughly once a month. 5) Details of all this are in the readme document which is on the napa CD!! If the above doesnt sort your problem try formatting it with windows according to the napas guide instructions. Good Luck! |
| Posted on Wednesday, January 04, 2006 - 04:26 pm: |
| Posted on Wednesday, January 04, 2006 - 04:36 pm: |
Another thing for those of you who sync with winodws media player, after putting on selected media onto your napa mp3 player if your getting an eorror message after disconncting it saying "no files" Change the settings in winodws media player by doing this: Open media plyer>click Sync>Click the small red tick icon near top right of the player> untick 'create folder hierarchy on device' un tickking the setting underneath is optional but i have it un ticked so i can manually add files myself.>Click Apply>Click O.K P.S You can also change the device name so it wont be called 'removal drive'. Now delete all previous content on your player or back it up. Close then re open windows media player. Then start adding your new files to the player as normal and these new settings will take affect. You should no longer have the no files error message! The reason for this error message is that napa mp3 players dont support all these folders that media player creates for each file on default. The player cannot naviagte throguh them. Done..Problem Solved!
illiterate-dumbass Unregistered guest |
| Posted on Monday, January 09, 2006 - 09:43 am: |
Hi I am thick as f)k and should not own an mp3 player, a computer or and internet connection, I am gonna ignore all te other posts in this thread and demand you fix my "incorrect format please reformat" problem. I will totaly ignore the fact that Balwinder Singh posted the solution in the 4th posting on this page. |
| Posted on Monday, January 23, 2006 - 03:30 pm: |
my grand daughter has a napa 128 mp3 player. we did not recieve any disc or software with it. it says just plug and play please help we are thick sh has had it since xmas and still no music on it thanks in anticipation thicko |
| Posted on Tuesday, January 24, 2006 - 03:12 pm: |
this shuld do it^ insert the mp3 player.go to my computer>right click removable disc>click format>then click start or go!  |
sam smart Unregistered guest |
| Posted on Wednesday, January 25, 2006 - 03:11 pm: |
Hi I av an ALBA MP3 player and its also saying incorrect format please reformat player could someone tell me how to fix this please |
New member Username: Srteja
Post Number: 1 Registered: Jan-06
| Posted on Tuesday, January 31, 2006 - 11:02 pm: |
Hi, I have an ADVIK 128mb usb mp3 player. Recently i installed the new firmware from the product cd.It has SigmaTEL MSCN Audio Player Firmware. After installing this, my player is not working. It is not playing songs even with new Battery and it is not recognized as removable drive in my computer. Anybody please give me the solution... |
Lost and confused Unregistered guest |
| Posted on Tuesday, February 07, 2006 - 03:28 pm: |
I have a Curtis SMP128 mp3 player, I have attempted to load it on my computer, running Windows XP. I am in need of the Sigma Tel MSCN audio player firmware, I am not able to access it from my computer. Can someone please let me know where to download this firmware from. Thanks |
| Posted on Friday, February 17, 2006 - 03:02 pm: |
Have a NAPA 1GB MP3 player when i turn it on it says incorrect format,Reformat the player,how do i do this.there was no disc with the player all i do is plug it into the usb port and drag and drop files into the drive |
| Posted on Sunday, February 19, 2006 - 09:00 am: |
Is there anyone who can help me get the driver/ software for my NAPA (LCD 512). I ca not copy or delete anything form this device. I can not even switch it on. Any body who can help? Than u in advance |
| Posted on Tuesday, February 28, 2006 - 01:16 pm: |
i have an alba boom 128mb mp3 player but i dont have the software 4 it is there a link 4 it please email me as soon as any one found it p.s. very urget |
| Posted on Thursday, March 02, 2006 - 02:25 pm: |
Where can I download firmware to napa pa32 player ?please help mee !!! |
New member Username: Rohitharora
Post Number: 1 Registered: Mar-06
| Posted on Thursday, March 23, 2006 - 01:23 am: |
have a napa mp3 pa70 1gb player which was working fine.I got the message on it saying incorrect format reformat the player.I tried to format thru winxp but couldnt.So i downloaded the firmaware softare of sigma tel mscn audio player as i did not have the orignal drivers that come with the player.Anyways i made the mistake of formatting the player without the battery. So now i have a formatted player that does not come on at all only when i connect to the comp with the play button pressed for 5 sec but it as for the drivers which i dont have. Please help or suggest where i can download the drivers or what to do. thanks |
New member Username: Allanson
Post Number: 1 Registered: Apr-06
| Posted on Wednesday, April 12, 2006 - 02:03 pm: |
PLIIIIIIIIIIIIIIIIIZ some one mailme awebsite were i can download NAPA 1gb LCD firmware,be coz it needs reformating.MA email is allan_son@hotmail,com |
New member Username: Waldo_uk
Post Number: 1 Registered: May-06
| Posted on Monday, May 08, 2006 - 07:09 am: |
Hi I have the 256mb version of the Napa mp3 and have the driver diak. I was getting the "incorrect format please reformat the player" and it wasn't working as a result. I found my driver disk after reading this forum and now it is working 100%. I will gladly share this driver with anyone that needs it. It is 13.8mb in total from the CD before 'zipping' or'rar'- ing. Let me know at daves_other-two@yahoo.co.uk and I will send as a zip.
New member Username: Raajl2
Surat,
Gujarat
| Posted on Tuesday, May 23, 2006 - 04:21 am: |
advik mp3 player new firmware need |
New member Username: Uffesteenberg
Post Number: 2 Registered: May-06
| Posted on Monday, May 29, 2006 - 04:22 am: |
Can anyone tell me if Napa players have a menu system that allows you to acces songs by album title?? I once had a player that just started playing songs from A to Z even though I sorted tracks in folders... quite annoying!! I'm looking at this one --> http://www.cy2000.net.ve/mp3/napa.jpg |
New member Username: Wink_bink
U.k.
| Posted on Monday, May 29, 2006 - 08:16 am: |
Hi i have tryed everything on this forum has anyone got any more ideas why the music doesnt play??? i put the mp3 player in to anyother computer and it shows it has all the songs on it but it will not play them. It is a napa pink 128 mp3 thanx |
Post Number: 2 Registered: Mar-06
| Posted on Tuesday, June 06, 2006 - 04:24 am: |
Thanks a ton for the drivers, but i cannot seem to understand why it does not come on even after loading the drivers. THe only way that it is recognised on the computer is when i remove the battery & keep the play buuton pressed while connecting to the computer, but after removing it & putting battery in, it just refuses to come on.Please help. |
New member Username: Ganusrs
Sirsi,
Karnataka
India
Post Number: 1 Registered: Jun-06
| Posted on Wednesday, June 07, 2006 - 02:15 am: |
When I formatted 2GB MP3 Player using Windows XP Fat32 it converted to 108MB please help me how to get remaining memory |
New member Username: Kamran_nisar
| Posted on Friday, June 09, 2006 - 09:19 am: |
HELPPPP!!! MY NAPA 256MB PLAYER ISNT DETECTED BY ANY CONPUTER! NOT HOME NOT UNI NOT EVEN ON MY PS2!!! I CAN PLAY THE SONGS WICH ARE ALREADY IN, BUT NOTHING DETECTS IT!!!! I EVEN TRYED REFORMATTING IT BUT IT NEVER DETECTS IT... HELP! MUCH APPRICIATED!
New member Username: Htel
| Posted on Tuesday, June 13, 2006 - 07:42 am: |
Original firmware is avaialble www.htelephones.co.uk or use the packard bell / logik as they are the same. These players have a design error and will all fail eventually. If it comes up "This device can peform faster" and no Removable drive appears then you will need to get your soldering iron out. These have a similar problem when you get a blank blue screen. All other 'faults' can be rectified with the firmware. |
New member Username: Daizie
| Posted on Tuesday, June 20, 2006 - 03:03 pm: |
Still can't hear music loudly enough even after saving as mp3 as advised (thankyou) can anyone help please? |
New member Username: Brousse
Post Number: 1 Registered: Aug-06
| Posted on Thursday, August 17, 2006 - 11:36 am: |
New member Username: U421224
DERBY UK
Post Number: 1 Registered: Oct-06
| Posted on Saturday, October 21, 2006 - 09:32 pm: |
I spent 2 hours on this, but nailed it and found mp3_recovery_drv.exe! What you need to do is download the file from http://service.packardbell.com/, (select (in order of page) select UK, select No serial number, select mp3 players,select Audioshare 2005 - 10>,select i dont know my model,select middle option (all available downloads) then under USB click file "MP3 Player Recovery Device Drivers 1.526.0.139 WinXP 29-11-2005". To go direct to this page, click http://support.packardbell.com/uk/item/index.php?i=platform_audioshare&g=2000 . Download it (mp3_recovery_drv.exe), install it and then run it (should appear as a new program within start on desk top). Once run, select Format data area then format ... click yes to disclaimer and yeeh hah .... dusted .... |
New member Username: Flamingatom
Philippines
Post Number: 2 Registered: Mar-07
| Posted on Thursday, March 08, 2007 - 08:21 am: |
hello, how i can revive my mp4? |
Philippines
Post Number: 3 Registered: Mar-07
| Posted on Thursday, March 08, 2007 - 08:29 am: |
can u help me pls? I have an mp4 STMP3500 and needs firmware update, i used the firmware on my cd but it didnt work, can u help me pls? email me at flamingatom@yahoo.com.ph thanx!! |
New member Username: Moay
Post Number: 1 Registered: Mar-07
| Posted on Sunday, March 25, 2007 - 08:12 pm: |
hallo if you have a nape mp3 and when you turn on the player a text show up and tell you Reformat the player. Do like this ? 1. Go to http://members.driverguide.com/driver/detail.php?driverid=498592 and login you can take my accont username: temp password: 512 2. download ,NapaMP3Drivers.exe and save or open. 3. install the software. 4. plugin your nape mp3 player. 5. go to ..start /all program /sigmatel mscn audio player/ firmware download. 6. click at start good luuck ..... /moay |
| Posted on Sunday, March 25, 2007 - 08:13 pm: |
hallo if you have a nape mp3 and when you turn on the player a text show up and tell you Reformat the player. Do like this 1. Go to http://members.driverguide.com/driver/detail.php?driverid=498592 and login you can take my accont username: temp password: 512 2. download ,NapaMP3Drivers.exe and save or open. 3. install the software. 4. plugin your nape mp3 player. 5. go to ..start /all program /sigmatel mscn audio player/ firmware download. 6. click at start good luuck ..... /moay |
New member Username: Phils_52
Post Number: 1 Registered: Apr-07
| Posted on Sunday, April 15, 2007 - 03:45 am: |
I recently bought this off ebay, Napa 1gb lcd player, no instructions or cd from po, came with music on whihc played ok. deleted play list manually, made up playlist on windows media and synchroniesed to device, deviceshows as loaded and when device opened on pc files are shown as folders for each artist. switch dvice on and it shows 'no files' help does any one have a instruction booklet that they could fax or e-mail please phil |
New member Username: Dramaqueen9753
Post Number: 1 Registered: Oct-07
| Posted on Sunday, October 14, 2007 - 12:02 pm: |
hello!!!!!!!! my computer keeps saying that it dont recognise my mp3 when im trying to save something on it or it says the device is not connected or busy. my mum says to reformat it. how? |
