Thread: Archive through March 08, 2005 |
New member Username: Mattbash243
Stevens point,
Wisconsin
United states
Post Number: 1 Registered: Dec-04
| Posted on Sunday, December 12, 2004 - 06:50 pm: |
my ipod is acting weird it wont to the menu or go back at all it is stuck on a play list and i tried shut it off and back on over and over gain but it wont do anything it just stays on the playlist |
Unregistered guest |
| Posted on Monday, December 20, 2004 - 05:32 am: |
I've just bought an i-pod 40gb and it won't link to my pc what am i doing wrong |
| Posted on Saturday, December 25, 2004 - 10:19 pm: |
help! i just got a mini ipod and i set up itunes and i already have songs on my ipod but when i put a cd in, i can't seem to put the songs from the cd onto itunes? HELP! |
ananymous Unregistered guest |
| Posted on Saturday, December 25, 2004 - 11:00 pm: |
i got an ipod and hooked it up to my computer but the songs from my iTunes playlist dont tranfer to my ipod
| Posted on Tuesday, December 28, 2004 - 12:28 am: |
I am having problems seeing files that are on my iPod on my PC |
| Posted on Wednesday, December 29, 2004 - 03:21 pm: |
I had copied about a hundred songs on my I-pod, and my brother installed his I-pod the other day and now I can't find my music. If I add music onto his name, will I lose all my previous songs that I have on my I-pod |
| Posted on Sunday, January 02, 2005 - 12:45 am: |
I just got my ipod. And i'm new with mp3s. So im clueless on this problem. The problem is that every time i plug in my ipod it tells me i need to format it but if i do it, it will erase all the memory on it , and it has about 3,000 songs already in it when i bought it used. |
Post Number: 2313 Registered: Dec-03
| Posted on Monday, January 03, 2005 - 07:00 pm: |
AJG, What is the operating system that the old owner used for the iPod? If you are not using the same operating system,i.e., the old owner used a MAC and you have a windows based sysetm, or vice versa, you will have to reformat. |
Post Number: 2314 Registered: Dec-03
| Posted on Monday, January 03, 2005 - 07:06 pm: |
spadd, Go to the display iPod options, click on the iPod tab and check the "manually manage songs and playlists". |
| Posted on Tuesday, January 04, 2005 - 03:07 pm: |
iv had my ipod for 6 months now, i already had music on my ipod, just recently when i added more on itunes the old music had exclamation marks next to them and on my ipod it would just play the newly added music and not the old, it just skipped past it. |
| Posted on Wednesday, January 05, 2005 - 09:50 pm: |
i got a 20gb ipod for christmas and when I try to play and import my cd's in itunes, it makes a scratching noise. i've tried everything I can but nothing works. |
New member Username: Dangumjessum
California
Post Number: 1 Registered: Jan-05
| Posted on Thursday, January 06, 2005 - 03:19 am: |
Hey, ive always had luck running Scandisk on my old Archos player and recently got an iPod (for $40, by the way!, click here - http://www.power2source.com/index.php?ref_id=6030)but i think that you should be able to run scandisk out of Windows when your Ipod is docked...Goodluck! |
| Posted on Sunday, January 09, 2005 - 11:29 pm: |
Help! I have many audio files on my ipod and have no clue how to place them in the audio book file thats built in the ipod, that way I can listen to shuffle and I don't have hear a audio book tracks between songs. thanks for any help........ |
| Posted on Monday, January 10, 2005 - 12:51 am: |
Help please!!! received a 40gb ipod for Christmas loaded 2000 songs on prior to leaving and then emigrated from UK to Australia. Arrived in Aus and songs were on there. went to load more songs onto the ipod and all songs went missing from the ipod. Now all that is there is a folder with an exclaimation mark on it. the warranty was lost in the move and apple wont help? can anybody else? please? |
Post Number: 2388 Registered: Dec-03
| Posted on Monday, January 10, 2005 - 09:04 am: |
If the ipod was set to automatic update, the ipod would automatically cross reference the songs on your ipod to the songs you have on your computer. If the songs are not on the computer, it will automatically erase those songs on the ipod. The exclamation marks mean that it tried to locate those marked songs on your computer and they were not found and it automatically erased them. For this not to happen, you have to change your preferences to "manually manage songs". If you have the same computer that you used to load the songs onto your ipod, all you have to do is "import file" or "import folder" to your "library" and the computer will automatically load all those songs back to your ipod. The missing songs is not apple's fault that is why they won't help. |
| Posted on Wednesday, January 12, 2005 - 08:59 pm: |
help!! My music won't copy onto my ipod!! I connect it in and it says copying music but then a few seconds later it says OK to disconnect,. I updated firmware and updaed itunes to 4.7.1 help. |
Post Number: 2438 Registered: Dec-03
| Posted on Thursday, January 13, 2005 - 08:17 am: |
connect the ipod, wait for the update. click on the ipod icon on the right corner of itunes. click on preferences. click on automatically manage music. close itunes restart itunes go to the left side of itunes and click on library. if you have music in there, it will be transferred to your ipod. now click on "my ipod" or whatever name you designated your ipod and see if there is music in there... you should have a list that will show up but they are not highlighted. do all this and let me know where the hang up is. cheers |
| Posted on Saturday, January 15, 2005 - 11:24 am: |
I got a 20 gig for Christmas, and I've got close to 650 songs on there right now... but all the music files on my computer is not flyin' with my mom. If I get rid of them, I I-pod gets rid of them too when I connect it. Would changing the setting to "Manually Manage" songs enable me to put the songs on the ipod, delete the file on the computer, but still be able to later load songs onto my ipod without it mirroring my library and therefore erase my deleted files? ...And if so, how do you go about load specific songs on there without losing the old ones? |
Post Number: 2463 Registered: Dec-03
| Posted on Saturday, January 15, 2005 - 12:28 pm: |
yes, if you manually manage your files, all the files in the iPod stays until you erase them.
andrewhampton Unregistered guest |
| Posted on Saturday, January 15, 2005 - 04:57 pm: |
My ipod wont charge, i cant turn it on...I just got it. Whats wrong? do I need a new battery? |
Jakeroell Unregistered guest |
| Posted on Saturday, January 15, 2005 - 08:31 pm: |
take it back to where you baught it from and tell them it wont turn on and you cant charge it and they will try and fix it and if not they give u a new one thats wut happend to me |
| Posted on Sunday, January 16, 2005 - 01:37 pm: |
Berny, from what i am reading, you are the person to come to who has all the right answers. So i have a question for you; i recently received an used Ipod, everything is fine with it except that the battery life is short cut (it runs for only 3 hours when fully charged) I have replacement Apple Ipod Slim Li-Ion Battery, but i refuse to intsall it myself, ie. I Dont Know What The Hell I Am Doing *lol* So the question remains, what and where should i begin the process of finding a technician to intsall the new battery? (i live in the NYC area)
| Posted on Sunday, January 16, 2005 - 06:09 pm: |
Ok, one day out of the blue I connected my ipod to update and my computer crashed. I don't know what happened it just messed up. so I disconnected the ipod restarted the comp and tried again. it didnt crash this time its just that itunes didnt recognise my ipod was connected. I updated itunes to 4.7 and tried again and again but it said my ipod was not connected, which it was. So what do I do? reinstall itunes from the cd?(if I can find it) will this action cause me to lose all my songs? please help I don't kow what to do. |
Post Number: 2473 Registered: Dec-03
| Posted on Sunday, January 16, 2005 - 06:59 pm: |
prodigious1 Try Best Buy or you can e-mail, the Ipod folks for instructions on how to replace the battery. |
Post Number: 2474 Registered: Dec-03
| Posted on Sunday, January 16, 2005 - 07:01 pm: |
Your songs should not disappear. First, check where your music is and verify that they are still in your computer. Make a backup file then re-install the iTunes. |
| Posted on Sunday, January 16, 2005 - 09:22 pm: |
i manually manage the songs on my 15 gb ipod on itunes, but my computer recently crashed and i had to reinstall, losing all of my files. when i hook up my ipod to my computer, the songs show on itunes, but i cant find teh actual files to load back onto my computer. its almost as if the songs are there, but not the actual mp3 files |
Post Number: 2476 Registered: Dec-03
| Posted on Sunday, January 16, 2005 - 09:32 pm: |
Is it still on the iPod? If it is, you can just transfer the music from your iPod to the computer. |
| Posted on Monday, January 17, 2005 - 03:21 pm: |
My ipod connects to the computer, but in itunes it does not register it is hooked up. What should I do? |
Post Number: 2480 Registered: Dec-03
| Posted on Monday, January 17, 2005 - 03:28 pm: |
Remove iTunes. Then re-install. Don't forget to back up your music files. |
moonshine9 Unregistered guest |
| Posted on Thursday, January 20, 2005 - 12:28 pm: |
Brand New 20GB 3rd Gen replacement Ipod (last one developed bad habits). When I connect it by firewire it won't come up in itunes (4.7.1) or on the desktop. Reset it, and tried reloading many times but no change. Any tips? |
Post Number: 2512 Registered: Dec-03
| Posted on Thursday, January 20, 2005 - 01:21 pm: |
Your computer can't detect it? Make sure that the firewire controller is functioning or enabled. If everything is good...return the defective unit. |
| Posted on Saturday, January 22, 2005 - 01:56 am: |
Just received 20gb IPOD. Connected to laptop to laod software and told that it needed to be fomatted. 12 hours later it's still doing it! Message on laptop is "waiting for ipod", message on IPOD is "do not disconnect"......any idea how long I just sit here? No details found on web for formatting problems! |
| Posted on Saturday, January 22, 2005 - 03:32 am: |
Is there a way to recover your songs once they are erased from your ipod? |
Post Number: 2527 Registered: Dec-03
| Posted on Saturday, January 22, 2005 - 11:09 am: |
DLR, If you are using XP, go to the lower right corner of your screen and click on the safely remove hardware icon and it will identify your iPod. After that, the message should disappear. |
Post Number: 2528 Registered: Dec-03
| Posted on Saturday, January 22, 2005 - 11:15 am: |
Anonymous, If you erased from your iPod and it is no longer on your computer, it is gone. |
| Posted on Saturday, January 22, 2005 - 11:34 pm: |
I just got a 20GB iPod and I connected it to my laptop, said it needed to be formatted and its taking a really long time, about an hour now. My laptop says waiting for iPod and the iPod says do not disconnect. i tried following the advice above by choosing safely remove hardware, but it says it cant so try again later. what do i do? |
SteveInCalif Unregistered guest |
| Posted on Sunday, January 23, 2005 - 01:34 am: |
I have Nikki's problem, too. Please help us. |
Post Number: 2537 Registered: Dec-03
| Posted on Sunday, January 23, 2005 - 10:11 am: |
try this open iTunes Go to the icon that says "eject iPod" After that, you shouldn't be able to see your iPod on the iTunes desktop. Then do the "safely remove hardware".
sirking Unregistered guest |
| Posted on Sunday, January 23, 2005 - 12:33 pm: |
All those list above are much to large! I believe in the system but you have to find fresh sites with empty lists! Here is one where you can get for sure a free X-box ( when I subscribed there were 2 members in list ) http://www.freegifts.be/index.php?ref=70 Free Gifts <img> |
MartiniMama Unregistered guest |
| Posted on Sunday, January 23, 2005 - 02:36 pm: |
In learning how itunes works I deleted a music file from my computer. It is still on my ipod. I have set my ipod to manual so it would't be delete. But I would like to go back to auto update. Is there anyway to get the song back into itunes so I can go back to auto updating? |
| Posted on Tuesday, January 25, 2005 - 12:39 pm: |
I have a 40GB iPod and just bought an 20GB iPod for my boyfriend, who is leaving for Iraq. I have imported 1,500 songs on my iTunes that I would like to put on his. I charged up his iPod, played his install CD, registered his iPod, and then iTunes had trouble recognizing the iPod (sometimes it would and sometimes it wouldn't) and would not transfer any music. The iPod finally stopped responding and flashed an error file. He leaves in a couple of days, so we took it back and exchanged it for a new one. Can you please give me instructions on installing his new iPod on my computer, so I don't repeat the previous mistakes. Do I have to erase all of my iPod and iTunes information, before I install his? Do I use his install CD? Your help would be greatly appreciated. |
Post Number: 2568 Registered: Dec-03
| Posted on Tuesday, January 25, 2005 - 12:51 pm: |
If you already have iTunes on your computer, DO NOT, install another program on top. The problem is that you probably already have an updated iTunes and when you installed another one using the CD, you will cause a conflict. You can use multiple iPods on 1 iTunes software, you just have to give each individual iPod a name so the computer can recognize it as a different machine. So, what you do is just put the new iPod on the cradle that you use for the other and it will prompt you on what you need to do next. Keep posting and let me know how you are faring. I know what its like...I've been to the sandbox quite a few times. Make sure he's got a lot of ziplock baggies and rubbers (non-lubricated) ...and no, the rubbers are not for personal use...you need it to cover the business end of his rifle. |
| Posted on Tuesday, January 25, 2005 - 01:22 pm: |
Thanks for your great advice (on everything). I will try it out ASAP. Do I have to have any particular settings for my iTunes before I connect his iPod? |
Post Number: 2570 Registered: Dec-03
| Posted on Tuesday, January 25, 2005 - 01:43 pm: |
none that I know of. |
Post Number: 2571 Registered: Dec-03
| Posted on Tuesday, January 25, 2005 - 01:54 pm: |
oh here's how to do that Look in your computer's Help documentation to learn how to set up additional user accounts. To locate this information, do the following: Click the Start Menu, and then point to Help or Help and Support. Enter new user in the Search field. Press Return. If you create multiple user accounts on one computer but want the same music to be available in iTunes for all users, see "iTunes: How to share music between different accounts on a single computer."
Post Number: 2572 Registered: Dec-03
| Posted on Tuesday, January 25, 2005 - 02:00 pm: |
Martinimama, Unfortunately with iPod, you cannot transfer the music back to your computer. It is only a oneway transfer. So always make sure that you have a backup copy of your songs. |
Post Number: 2573 Registered: Dec-03
| Posted on Tuesday, January 25, 2005 - 02:04 pm: |
| Posted on Thursday, January 27, 2005 - 02:21 pm: |
Its possiable to take music off an Ipod on windows xp(havnt tried it with any other os's). just change the file view options so you can see hidden files. Then open your ipod up in my computer (explore) and you can see all your MP3s. |
Post Number: 2612 Registered: Dec-03
| Posted on Friday, January 28, 2005 - 08:03 am: |
Try it...but like I said the transfer is only 1 way. However, you can use the iPod as a hard drive and you can transfer files in and out. So go from there. I haven't tried that, I only use the iPod for music. |
mahimahi Unregistered guest |
| Posted on Saturday, January 29, 2005 - 08:32 pm: |
I have an ipod 20 gb and have itunes set on manual. im just woried that if i reformat my computer and reinstall itunes that itunes will not recognize that i want to manually manage my ipod and will delete all my music. Will this happen? or is the automatically manage files written into the actual ipod? |
Post Number: 2638 Registered: Dec-03
| Posted on Saturday, January 29, 2005 - 10:50 pm: |
One reason why it is a good idea to back all your music files. Once you re-install iTunes, you go to the preferences dialog and toggle on "manually manage songs". Do all of these before you actually dock your iPod. That way, you don't erase the files in the iPod. |
| Posted on Saturday, January 29, 2005 - 11:10 pm: |
I got an 40G Ipod gor xmas, i also got a new computer. But the computer didnot come until today. when i hook up my new computer the old computer will disassimbled for parts. I am planning on reinstalling itunes on the new pc, but i have to 7.5G's and i dont want to have set for ever reinstall the music. how can i install on new computer with out reformating the Ipod? |
Post Number: 2641 Registered: Dec-03
| Posted on Saturday, January 29, 2005 - 11:28 pm: |
You don't have to reformat the iPod. You have to find a way to install your music from the old computer to the new computer. Do that first then we'll go from there. |
| Posted on Saturday, January 29, 2005 - 11:44 pm: |
I havent been saving the music to my computer cause i only have 25G's totaol space and i dont want to use all my space for my Ipod. if i install the new itune on the new computer, it wont erase the ones that i have then? cause i had it installed on my moms computer and when i installed it to this on it erased the hard drive. i just want to make sure that it wont do that again. Thanks |
Post Number: 2642 Registered: Dec-03
| Posted on Sunday, January 30, 2005 - 10:29 am: |
Just be very careful that you do not have the iTunes on automatic update and you should be fine. But once you put it on automatic, all the music in your iPod is toast. If you have 25 gig's worth of music make sure that you transfer all of it to the new computer. Borrow a portable hard drive if you can. |
| Posted on Monday, January 31, 2005 - 09:06 am: |
I have an iPod 40Gb. Have been loading up fine from CD's to Library and then to iPod. Yesterday, imported CD to library ok but itunes seemed to automatically copy to a SYS device. Previously when I connected the iPod it displayed it as a device under Library using my name. Now it shows up as SYS but songs won't copy to it. Any suggestions ?
Buttonsfly Unregistered guest |
| Posted on Monday, January 31, 2005 - 04:54 pm: |
Hi have a 40g iPod, it has been working fine with itunes, but now the computer has just stopped recognising it, i have reinstalled both itunes and ipod software, but did not let the computer configure the ipod, as i didn't want to wipe the music, i have my music backup to dvd so if i have to reconfigure the ipod i will, any suggestions please! |
Post Number: 2660 Registered: Dec-03
| Posted on Monday, January 31, 2005 - 08:42 pm: |
victorghoti, Have you tried resetting your iPod? Buttonsfly, Make sure that you have the latest version of iTunes. Then make sure that your cablea are still good...try using different ports on your computer, if available, to rule out connection problems. |
Gemma Nicol Unregistered guest |
| Posted on Tuesday, February 01, 2005 - 06:39 am: |
I have got a 15GB IPOD, BUT I HAVE NOT INSTALLED THE CD ONTO MY PC YET AND I HAVE NOW DISC0VERED HAT I HAVE LOST THE CD IS THERE ANY WAY IN WHICH I CAN GET SONGS ONTOT MY IPOD WITHOUT INSTALLING THE CD? CAN I DOWNLOAD THE STUFF I NEED FROM NE WHERE ELSE? |
Post Number: 2664 Registered: Dec-03
| Posted on Tuesday, February 01, 2005 - 07:39 am: |
You can go to apple.com website and download iTunes. |
PassionLei Unregistered guest |
| Posted on Thursday, February 03, 2005 - 11:59 pm: |
I have a 40gb ipod and I can't seem to get my itunes to import songs from a cd. When I insert a cd, my itunes doesn't load. I've only had itunes successfully read a cd once and it wouldn't import the songs. Can someone please help me? |
Post Number: 2683 Registered: Dec-03
| Posted on Friday, February 04, 2005 - 07:31 am: |
You have to configure the iTunes as your default player. Then you have to tell the iTunes where you want to import the cd that you rip. Try this: When you put in a music CD, right click on the drive where you have the CD. Then choose "open with"...from there you should get different choices and you can choose "iTunes". When that box opens you have an icon on the top right corner. When you mouse over that, it will say "import". But you have to go to your preferences dialog and configure the iTunes player where to put the imported cd. |
New member Username: Lena_smv
Post Number: 1 Registered: Feb-05
| Posted on Friday, February 04, 2005 - 05:22 pm: |
I seem to be having problems with connecting my iPod to my computer. The first time, iTunes said my iPod wasnt connected, although my iPod said "Do Not Disconnect" on the screen. It worked after a while, and i used transferred music twice. However, the last time i tried my iPod didnt seem to be connected to the computer, and iTunes says its not connected. What should i do?! i need help! |
| Posted on Saturday, February 05, 2005 - 04:21 pm: |
I just got an ipod for christmas and recently it started freezing constantly. After i reseted it, the apple logo came up followed by a folder with an exclamation mark. My Ipod go back to the main menu anymore. Does anyone have any advice |
krazykongo Unregistered guest |
| Posted on Saturday, February 05, 2005 - 06:19 pm: |
is the ipod recognised as a mass storage device, so i can use it as a portable hard drive? can i use the ipod without itunes when transferring songs? can i store data files etc.. on my ipod and transfer to other pc? |
Post Number: 2703 Registered: Dec-03
| Posted on Monday, February 07, 2005 - 07:37 am: |
Elena, First back up your music files. Then uninstall the iTunes Program. Restart the computer, install iTunes and update to the most current version. Go through all the motions of installation then dock your iPod ONLY after the install. Check that your cables are not damaged in any way. |
Post Number: 2704 Registered: Dec-03
| Posted on Monday, February 07, 2005 - 07:51 am: |
Brien, If you see an exclamation point on the iPod folder, it may have been reformatted. So, you need to make sure that when resetting, the iPod is not connected to the computer at all. To avoid problems, make sure that the software is installed and updated before docking the iPod. This is a common mistake...software first, THEN, dock. Krazykongo, Yes you can use the iPod as a mass storage device or a hard disk. Yes you can transfer music without iTunes if you are using it as a mass storage device, but you will not be able to play them. |
| Posted on Monday, February 07, 2005 - 09:56 pm: |
help - i turned on administrator settings with windows XP, setting up accounts for different users, and now my IPOD library has disappeared |
Post Number: 2712 Registered: Dec-03
| Posted on Wednesday, February 09, 2005 - 01:16 pm: |
Can you still use iTunes? If you can, just do a music files search and add to library. |
| Posted on Tuesday, February 15, 2005 - 09:26 am: |
I have the same problem as Nikki in the posting on January 22. I am formatting my device, and it is taking a LONG time. iTunes is not yet installed, as this formatting was required before installing iTunes... so I am not able to choose "Eject iPod". How can I safely remove hardware when Windows will not let it stop? |
Post Number: 2738 Registered: Dec-03
| Posted on Tuesday, February 15, 2005 - 09:46 am: |
Turn off the computer, then remove the iPod. iTunes need to be installed first before doing anything with youriPod.
John Ricartoe Unregistered guest |
| Posted on Wednesday, February 16, 2005 - 07:19 am: |
After reading all of your posts i realise that you want the software i used, it cost me £12 but was definately worth it, i recovered 100% of my songs - all 3376 of them and all the contacts and everything, it is a speacialist ipod recovery software have a look you might like it, but god it will save you all!!! http://www.ipodrestore.uni.cc |
| Posted on Friday, February 18, 2005 - 12:17 am: |
I am wondering if anyone knows how to transfer music that is already on my ipod to a new apple computer I recently purchased? Thanks |
Post Number: 2754 Registered: Dec-03
| Posted on Friday, February 18, 2005 - 07:13 am: |
Why don't you just transfer all the data from your old computer into the new one? Unless you were using a windows pased pc. |
frodohcs Unregistered guest |
| Posted on Saturday, February 19, 2005 - 01:04 pm: |
my ipod wont turn on or charge |
Post Number: 2762 Registered: Dec-03
| Posted on Tuesday, February 22, 2005 - 07:14 am: |
how old is it? |
New member Username: Lynchdg
| Posted on Tuesday, February 22, 2005 - 06:05 pm: |
Hi, I recently purchased a 4th generation I-pod as a replacement for my 3rd gen model which was stolen. I was hoping I could just hook up my new I-pod to my existing I-Tunes library. However when I do connect it recognises the I-pod but claims that the software is not installed. If I attempt to Install the version of I-tunes I recieved with my second I-pod will it update, keeping my library or overwrite the existing I-tunes deleting all my songs. Any help or suggestions would be much appreciated. |
Post Number: 2767 Registered: Dec-03
| Posted on Tuesday, February 22, 2005 - 10:13 pm: |
It shouldn't delete any of the songs. You are just updating the program. Just to be safe back up all your songs to a CD or DVD. |
New member Username: Memmeeme
| Posted on Wednesday, February 23, 2005 - 02:12 am: |
Ok, so I know this wasn't the smartest thing to do, but I was trying to move alot of stuff from one computer to another, so I tried using my iPod. I didn't have enough room, so I got rid of all the music in the music folder on the iPod, thinking I could just re-upload it. Now my iPod keeps cycling through the list of music that should be there, and doesn't connect to the computer anymore. Any suggestions? |
Post Number: 2770 Registered: Dec-03
| Posted on Wednesday, February 23, 2005 - 08:04 am: |
How were you able to erase the music in the iPod? |
Post Number: 2 Registered: Feb-05
| Posted on Wednesday, February 23, 2005 - 09:40 am: |
When it was hooked up to my pc, there was a hidden folder with the music folder in it. |
Post Number: 2775 Registered: Dec-03
| Posted on Wednesday, February 23, 2005 - 10:52 am: |
Sorry for my confusion. Is the iPod completely empty of any music files? The music folder on your compuer is also gone, correct? If you left the music on the iPod, you will not be able to transfer it back from the iPod to the PC. It is a one way transfer. |
Post Number: 3 Registered: Feb-05
| Posted on Wednesday, February 23, 2005 - 04:13 pm: |
No, I deleted the music out of the music folder on the iPod itself, the music is still on my computer. |
| Posted on Wednesday, February 23, 2005 - 06:19 pm: |
Does anyone know a number to Apple because I broke my iPod and I want to know if I can get it replaced |
Ladybug Unregistered guest |
| Posted on Thursday, February 24, 2005 - 06:46 am: |
Gerald if you go to apple.com it should list the number for you nearest store and the technical support number. |
Steven Bernitt Unregistered guest |
| Posted on Thursday, February 24, 2005 - 06:43 pm: |
I had to clear my computer of everything so my songs are gone. Is there a way to put the songs from my ipod back onto itunes? |
Post Number: 4 Registered: Feb-05
| Posted on Friday, February 25, 2005 - 01:41 am: |
Steven, you could try to do it the way I accidentally deleted all my songs and find the music folder on your iPod when its connected to the computer, and copy all the folders called F00, F01,...etc back to your computer. |
| Posted on Sunday, February 27, 2005 - 09:39 pm: |
i just got a mini ipod and i loaded everythiing on my computer and got a 2.0 usb card for my labtop but my computer wont recognize the ipod...it just keeps blinking "do not disconnect". ive tried uninstalling and installing itunes but nothing works. it happened to a person i know and they brought it back adn got a new one that worked fine..but i don't have a car so i was wondering if there was anyway to fix it without returning it. |
| Posted on Sunday, February 27, 2005 - 11:25 pm: |
After a hard drop to the floor, iPod had sluggish controls. After a reset, all songs were gone! After discharging iPod, controls are better, and computer recognized it, but loading song library stops after a few songs. Seems to load a few songs at at time, and then stops. Should I try a restore? Does iPod need servicing? |
| Posted on Monday, February 28, 2005 - 09:37 pm: |
ok im like really close of buying a mini ipod but what im hearing from other people is that you could only use it on one computer and if i use it on another computer or itunes all my music will erase and im not even sure if i wanna buy it anymore cause i have only one computer that is really slow and cant get itunes into so what do i do??? |
Post Number: 2806 Registered: Dec-03
| Posted on Tuesday, March 01, 2005 - 07:51 am: |
Get a different mp3 player. The iPod mini does not seem to be the one for you.
| Posted on Wednesday, March 02, 2005 - 09:21 pm: |
Hi, First I really appreciate what you r doin here, so patient, i'm sorry if my questions have been asked before- but I did scroll up and down and didnt see the answer I have the same problem as jason thomas and "anonymous", I just bought a mini and I have installed itunes and even bought music, But when I tried connectng both trhu my IEEE and USB port , the ipod said dont disconnect for like hours and finally I had to "safely remove hardware"- Th eject button didnt work either, and when I went to edit/preference/ ipod- said no ipod connected, what am i doin wrong? Que 2 )Also I dont want all the songs on my comp in my ipod and by default they are all in my itunes.How do i prevent all rubbish songs from going on my ipod. Thank you again, May the Ipod God bless u
| Posted on Thursday, March 03, 2005 - 08:10 pm: |
My ipod wont update my songs. When I plug in my ipod on the ipod screen it says do not disconnect yet on my computer screen nothing is happening. There is no icon in the right corner showing an ipod, and it says that my ipod isnt connected even when it is. What should I do? |
| Posted on Thursday, March 03, 2005 - 09:25 pm: |
my ipod has frozen. i know how to reset it, but it will not reset, any idea what to do? |
| Posted on Friday, March 04, 2005 - 09:54 pm: |
hello, my ipod is stuffed and won't turn on. i've done every thing but a sign with a folder and exclamation mark keeps showing up on screen. i have tried to reset, restore factory settings but nothing is coming up. please help me asap. |
| Posted on Friday, March 04, 2005 - 09:56 pm: |
| Posted on Saturday, March 05, 2005 - 03:31 pm: |
hey, today i went to turn on my ipod, and the apple screen came up, then it just froze. i have done both resets and hard resets and nohting seems to work. any ideas? |
| Posted on Sunday, March 06, 2005 - 07:34 am: |
i did the dumbest thing. i tinkered with the setting that automatically launches itunes when you connect your ipod. now itunes won't recognize my ipod!! so i can't upload any songs onto my ipod. i've tried reinstalling my itunes, but i'm still having the same problem. does anyone have any ideas? thanks! |
| Posted on Tuesday, March 08, 2005 - 04:14 pm: |
i put my ipod into my computer and it said do not disconnect for hours, i then safely disconnected it and tried again, the same is happening and i dont know how to fix it, if anyone can help please do |
New member Username: Itisnteasy
Post Number: 1 Registered: Mar-05
| Posted on Tuesday, March 08, 2005 - 05:23 pm: |
i have a 40gb ipod and when i turn it on, the 6000 songs i have loaded on it do not show up under the songs, artists, album, etc. icons, however, when i look under settings, the capacity still shows that I have 11GB remaining, 25GB used. Does that mean that the songs are still trapped in the ipod? I can see the songs when I connect the ipod to the computer, they show up, but when i try to access them on the ipod, storage hasn't changed, but i cannot get to them, any ideas??thanks |
