Thread: IPod wont copy songs over |
Unregistered guest |
| Posted on Wednesday, September 07, 2005 - 12:03 am: |
please help me. i have a weird situation with my 4GB mini ipod. when i hook it up to the computer it dosent read that its hooked up. i have a mac and it USED to show that i had an ipod and it would show up on the desktop. now it dosent. also it used to have a lightning bolt showing that it was charging. but now it dosent have the bolt...yet it still getc charged even though the computer says i have no ipod attached. i recently got lots of new songs and want to upload them to my ipod but itunes dosent realize its hooked up PLEASE HELP ME! mjennings@lejardinacademy.com |
Relevant Product Info
| Posted on Monday, September 12, 2005 - 07:12 am: |
Plug the iPod to the cable, and attatch to your computer/desktop through USB port. Then, reset your iPod by holding the midde button and the menu button simultaneously. Worked for me, hope it does for you. |
| Posted on Wednesday, September 21, 2005 - 01:43 am: |
I have iTunes and Limewire....all the music I download is through Limewire but i can't import the music I download into my iTunes library. Can someone please help? |
| Posted on Friday, September 23, 2005 - 08:13 am: |
i got an error while trying to add files manually, it said the file type was too deep?? it was just a simple mp3 too... |
New member Username: Pukinghobo
Post Number: 1 Registered: Sep-05
| Posted on Wednesday, September 28, 2005 - 12:57 am: |
dude, its not that hard to download the songs from your ipod to your computer. no you dont have to download any other programs to do it . |
| Posted on Sunday, October 02, 2005 - 09:07 pm: |
i am trying to upload music in my ipod to itunes as well but i cant see any music folder when i open my ipod drive. where the hell is all the music? |
New member Username: Satter09
Post Number: 1 Registered: Oct-05
| Posted on Sunday, October 02, 2005 - 11:01 pm: |
I just need help...I set up itunes on my moms computer and bought 30 songs and they transfered over to my ipod. The other day I plugged in my ipod and opened itunes and my moms playlist that she listens to on Winmix got transfered over to my itunes, erased my "bought" music from my ipod and now I have my moms Winmix music on my ipod...How do I get rid of her playlist and get the music I bought back om my ipod? |
lisa123456789 Unregistered guest |
| Posted on Sunday, October 16, 2005 - 02:37 pm: |
i have Lime Wire music on itunes but not in the library. what "BERNY" suggested didn't work. how can i import Lime Wire music into y itunes library? please help me! |
| Posted on Saturday, October 29, 2005 - 04:22 pm: |
I don't have itunes because I have windows 98 but i have limewire and i'm tryin to put my songs on to my mp3 player and I don't know how!!!! Help!!!! i neda no asap plz |
jojomejojo Unregistered guest |
| Posted on Saturday, October 29, 2005 - 05:35 pm: |
I have the same problem i wanto gte lime wire music from lime wire onto my ipod but i have no idea ? what do i do!!!!!!!!!!!!! |
Post Number: 2 Registered: Sep-05
| Posted on Sunday, October 30, 2005 - 02:01 am: |
well what are you doing? what i do is the songs i get off of limewire i just drag them to deck top and have itunes open and then drag the songs frm desk top itunes |
Audiogal Unregistered guest |
| Posted on Monday, October 31, 2005 - 11:34 pm: |
To import LimeWire tunes into iTunes, you can either have both programs open, and simply drag the files from LimeWire (under "library") into iTunes OR in iTunes, click on "File" and then "add file to library", browse for the file, and it's added to iTunes. If you don't have iTunes, you should be able to find where LimeWire saves the songs and drag or copy them to whatever program you use to update your mp3 player. |
| Posted on Tuesday, November 01, 2005 - 03:43 pm: |
i have a dell computer, so my ipod is already formatted to windows. i just got a new mac ibook, and i want to put my songs onto the new computer, but it tells me i can't do that without reformatting and losing all my songs. is there another way? |
Post Number: 4204 Registered: Dec-03
| Posted on Tuesday, November 01, 2005 - 04:28 pm: |
What other way do you think there is? Did you think that "it" was lying just out of spite? You have 2 different operating systems that are not compatible with each other. These are programs that are not made for each other. So guess what? you have to reformat. Just back up your songs on a disk and rip it back to your iBook. |
| Posted on Tuesday, November 01, 2005 - 05:00 pm: |
Hi. I would greatly appreciate anybody who could help me with this problem. I am trying to copy the songs from my iPod Nano to my iTunes; I am also using a MAC and saw somebody's suggestion of copying the files but that didn't work for me. When I open my iPod I don't see the songs. Anybody have any suggestions? Thanks a lot! |
| Posted on Tuesday, November 01, 2005 - 06:12 pm: |
I am trying to put all my songs from my ipod to a new computer and i need help. Sum1 pleeze help me. |
Post Number: 3 Registered: Sep-05
| Posted on Tuesday, November 01, 2005 - 11:34 pm: |
this is how i did that to. open iTunes then hold ctrl+, a window should open you click ipod. ok then you should click manually manage songs and playlist. open my computer. click on the usb drive where your ipod it in. make sure you computer shows all the hidden files. open ipod_control they shouls be 3 folders open the folder that says " music".they should be a hell of alot of folders in that folder. part 2 in one day i got bored |
| Posted on Thursday, November 03, 2005 - 09:52 am: |
Hey I think this question was kind of answered above, but I just wanna make sure. I got limewire last night, and I downloaded about 30 songs. It automatically transferred into iTunes but, when I connected my ipod to the computer those songs didn't load :-/ And for those of you with itunes [you'll kno what I'm talking about] I can't rate the songs, change the title, or drag them into another playlist. It's just like they're there and that's it. How do I get them on my ipod? I can't even burn them onto CD's! |
CChumpy Unregistered guest |
| Posted on Sunday, November 06, 2005 - 09:32 pm: |
Mine did this after I got a new computer... It wouldn't transfer ANY of the songs to my ipod and would continually say "DO not disconnect" on my ipod. Once I played a new purchased song on itunes, it authorized my new computer and they all transferred! THANK GOD! *mumbles* I really hate mac stuff...grrr. |
| Posted on Tuesday, November 08, 2005 - 12:30 am: |
Peacepower, Are the songs just listed under "Limewire" or something similar in iTunes? If so, iTunes is just remembering which songs you downloaded but they have not actually been added into iTunes. You have to manually add them into the iTunes library so that you can download the songs to your iPod and edit the song info. |
| Posted on Tuesday, November 15, 2005 - 04:56 pm: |
hi, i transferred my songs from limewire to my itunes, and they are visible in my library. when I autofill they are all there, but when I take my ipod out of the computer, my green status light stays on and none of the songs play...can you help me please?... |
ipodproblemm Unregistered guest |
| Posted on Friday, November 18, 2005 - 11:03 am: |
Hi im thinking of getting an ipod nano for christmas, but i need to know if my songs that i have downloaded from limewire will go onto my new ipod ok? or how i can make them go on ok? i have a normal mp3 player at the moment and limewire goes on there fine will it be the same for ipods???? can anyone help me please... many thanks
| Posted on Friday, November 18, 2005 - 10:23 pm: |
Check that it says "Note: You cannot transfer songs or playlists from iPod to iTunes." at the end of the webpage at the URL below. http://docs.info.apple.com/article.html?path=iTunesWin/4.9/en/794win.html |
khabokirani Unregistered guest |
| Posted on Friday, November 25, 2005 - 09:39 pm: |
anyone who has the ipod not getting recognized problem, get ready to be relieved!!!!!!! i figured out what the problem is. okay guys check to see if your device manager is blank when you open it, if it is then you had the same problem as me! i spent hours talking to microsoft and we finally figured out a solution! the problem is the device manager which doesnt recognize the ipod. the cause of this problem is the **** windows update which downloaded this update on my computer which was causign the problem! get rid of this update from your computer and you're home free!!!!!!!! the name of update is KB905749... reply if you need help deleting this update!!! i'm so happy it's finally fixed... after i fixed this everything was normal, i did have to restore my ipod completely first though |
| Posted on Monday, December 26, 2005 - 10:51 am: |
i have a ipod nano im trying to transfer my songs from a cd over to my ipod i did exactly as it said in the instructions incert cd itunes pops up i hit export then my ipod says do not disconnect thats all it says after hours i disconnect and no songs are there HELP PLEASE |
| Posted on Monday, December 26, 2005 - 06:47 pm: |
hi ... i downloaded some songs of limewire and there in itunes but i canot get them into the library.. how do i do this? plllllz can someone help me ...sophie xoxox |
gotipod. needsongs Unregistered guest |
| Posted on Tuesday, December 27, 2005 - 12:32 am: |
Hey I just got a ipod music video which can hold like 7500 songs and I can't get my limewire music into my itunes library. just like "sofras" message. Please help us! thanx! |
reneeneedshelp Unregistered guest |
| Posted on Tuesday, December 27, 2005 - 10:35 pm: |
I had my ipod mini for a few months, but I havent found out how to put songs on it. I fooled around with Itunes for a bit and got a few songs on my ipod but I cant remember what I did!! All my Limewire songs are on Itunes but I dont know how to put those songs onto my ipod. When I go to "file..import" then nothing happens!! What am I doing wrong? |
| Posted on Tuesday, December 27, 2005 - 10:43 pm: |
i have a new ipod nano and i need some songs from lime wire and i cant seem to find out how to put them on itunes...some 1 help me fast...i cant live without my favorite music!!! |
Justinlaveck Unregistered guest |
| Posted on Friday, December 30, 2005 - 04:54 pm: |
ok i just got an iPod Video with 30GB and when I open iTunes there is no iPod icon and i just can't figure out how to put songs and videos into my iPod...could someone help me  |
| Posted on Sunday, January 01, 2006 - 01:25 am: |
hi i have an ipod mini and i charged it one night and when i used it the next day and tried to listen to it ALL of my songs played with very poor quality and u can hear the beat of the songs but u can barely hear the words for all my songs. PLEASE HELP |
| Posted on Sunday, January 01, 2006 - 04:44 pm: |
Lime Wire to Ipod... 1st Go to Itune preferences and make sure music is in consistant format MP3.. Go to lime wire , select your music files, right click and highlight launch.This should puts your Itunes in Ipod library. Go to Itunes "your lime wire folders should be there" , select music files to upload to ipod |
Ricky231 Unregistered guest |
| Posted on Wednesday, January 04, 2006 - 02:03 pm: |
I have a problem with iTunes, It Just won't open...it opens, but almost a second later it closes on it's own, so i have not been able to load any songs onto my ipod!, i really need help! Please! |
| Posted on Saturday, January 07, 2006 - 12:09 am: |
Hi, i'm having sort of the same problem as everyone else here. I got an ipod nano a while ago, and my songs transfer onto it fine, except for certain ones. They are the same format as the other songs and are MPEG-1 level 3 (whatever that means..) but when i try to put them on a message pops up saying that my ipod is full, but even when i empty my ipod of all other songs and try to put them in, it still says my ipod's full...even though i KNOW for sure that it isn't..why is this happening? please help me...i just want to listen to my pink floyd  |
anonymous02 Unregistered guest |
| Posted on Saturday, January 07, 2006 - 07:27 pm: |
is there any other program i can use instead of iTunes to transfer songs over to my ipod!?. The reason i'm wondering is because my iTunes will not open, it only opens for about 2 seconds and closes almost immediately...so i was wondering if anyone had any information on how to get this fixed. Well if anyone does I would really appreciate if you helped! Please! |
bruce64 Unregistered guest |
| Posted on Saturday, January 07, 2006 - 08:24 pm: |
SOLVED IT- just re add the folder. It will only add what is missing. |
flatstanley Unregistered guest |
| Posted on Sunday, January 08, 2006 - 03:00 am: |
umm not sure if this helps aswell but, when u upload ur songs, make sure, ur 'updating thingy' is not on ur playlist selection only... righclick ur ipod in itunes, go ipod options, and choose automatically update all songs and playlists... dunno if that helps |
| Posted on Monday, January 09, 2006 - 06:19 pm: |
how do i get video clips from limewire on to my ipod? i got them in my itunes library and i tunes will play them but it won't export to the ipod |
| Posted on Monday, January 09, 2006 - 10:38 pm: |
I had to buy a new computer a month ago and i tried to connect my ipod to it to put all of my music on my new computer, turns out that it all got deleted by the wrong click of a button..what do i do if i would like to try doing this on a different computer |
| Posted on Wednesday, January 11, 2006 - 10:32 am: |
I'm curious about deleting the KB905749 file mentioned on Nov 25. My PC won't recognize my ipod either, nor does itunes. Has anyone tried deleting this successfully? |
| Posted on Wednesday, January 11, 2006 - 06:37 pm: |
hi im trying to take music from my Limewire and put it on my Ipod but its not working.. please help me i have been trying for a long time. |
shereena Unregistered guest |
| Posted on Wednesday, January 11, 2006 - 06:45 pm: |
hello im trying to take music from my Limewire and put it on my Ipod but its not working.. please help me i have been trying for a long time. |
| Posted on Saturday, January 14, 2006 - 02:25 pm: |
i hav same problem too i want to put my mp3 songs that i hav already got on my computer onto my ipod nano. downloaded songs using limewire :P i hav already ripped songs from albums i have before i even got the ipod nano!!! |
New member Username: Jafstar
Post Number: 1 Registered: Jan-06
| Posted on Monday, January 16, 2006 - 08:55 am: |
Hey all ive gt a solution i hope it will work for u all it worked fr me listen theres a new program called Podplus if ur like me u dont have all the songs on ur computer that u downloaded on ur ipod neways using tht problem u can copy ur songs from ur ipod into ur computer once uve made sure all ur songs are backed up downlad ipod updater and using it reset ur ipod to factory settings once done open itunes and copy all ur songs from where u downloaded em into ur library and then update it and hopefully it will work sorry fr u guys who gt the nano or video im nt sure if its the same bt this has worked with my photo hope it works Jafstar |
themadgaffler Unregistered guest |
| Posted on Monday, January 16, 2006 - 11:47 pm: |
I have a 30 gb ipod. I also bought one for my wife. I installed the software on one computer and dled a zillion songs. I connected her ipod (30 gb also) and it updated and charged. I then connected my ipod and it updated, however it will not charge. after the update, it stops charging and just stays on without charging. any advice? i have tried resetting and reinstalling itunes. i tried different usb ports and cables. i was very particular about following all directions to a tee. it would seem that one should be able to use a single computer to udate and charge multiple pods......this is frustrating. =( |
Post Number: 2 Registered: Jan-06
| Posted on Tuesday, January 17, 2006 - 03:40 am: |
erm have u tried downloading the software upgrade for her ipod, perhaps if u upgrae her software with that it might work...however i found that the new software if not great so i used the software to change the software back to facotry settings try both things it shud work, its usually not the problem with the cables but with the ipod itself Jafs |
| Posted on Tuesday, January 17, 2006 - 06:17 pm: |
update - talked to technical support and he helped me restore my ipods software (lost 7000 songs- i was really happy about that). after that didnt work he says i have to send it in to get fixxed. this thing is a week old. pretty poor quality assurance id say. |
New member Username: Libbie
| Posted on Wednesday, January 18, 2006 - 04:13 pm: |
/quote Just got my Apple Ipod. I downloaded an album to library on pc. How do i download it to my ipod? please help its driving me mad! and does anyone know any good sites to download up to date music. thanks you first need to install iTunes on your computer, even if you already have it, please use the disk that came with your iPod. then using the high powered USB port, depending on your computer, it may be in the back (On my Dell it is). iTunes should open automatically, and create a connection with the iPod. It will automatically add all the music on your iTunes to your iPod. Please, don't disconnect your iPod until you see the "iPod Updated" message, then click the eject icon on the iTunes where your iPod is and wait until your iPod is cleared of this message. That should transfer all the music on your iTunes to your iPod with no problems. |
| Posted on Wednesday, January 18, 2006 - 04:17 pm: |
"Could Apple have made the screen on my $300.00+ IPOD 30GB Photo out of any softer material? Heck, if I just touch it with my finger it scratches...very crappy engineering...paying endlessly just for looks/styling NOT PERFORMANCE (locks up every other day and many others shave better sound quality and more useful easy to use features)) AND DURABILITY (impossible to keep it clean unless kept under glass -designed to need replacing). Just a hard drive and software - very poor value." First off, invest in a pod protection skin, I got one on ebay for under $20. It is well worth it, the screen is like any other glass screen, it will scratch. I think a $20 investment is well worth it ,considering the price of the actual iPod. Second, most errors on the iPod are user related. Things such as unplugging when it says do not disconnect, not scanning songs for viruses before uploading, other things. IF you follow the directions in your manual, unless you have a crap iPod, you will be fine. |
Post Number: 7 Registered: Jan-06
| Posted on Wednesday, January 18, 2006 - 04:51 pm: |
ok i just got an iPod Video with 30GB and when I open iTunes there is no iPod icon and i just can't figure out how to put songs and videos into my iPod...could someone help me is your iPod plugged into the highpowered USB 2.0 on your computer? Plug in your iPod first, then it should open iTunes automatically. It will update automatically unless you have chosen to do a manual update instead. DO NOT DISCONNECT the iPod until it is done updating, then click the "eject" icon to disconnect the iPod.
| Posted on Friday, January 20, 2006 - 01:18 pm: |
hey i seem 2 b havin da same prob as most people i got an ipod nano 4 xmas and until a few dys ago worked fine but suddenly all my songs were deleted and when i tey putting them back on agen the computer ses they're on there but ther not on the ipod, i avent changed anything n seemed 2 hav tryed evrything i cold think of but im only 14 so not so gd with the technical stuff, plz cud u help me i cant liv without my ipod!! |
