Thread: Conversion problem |
New member Username: Philygraham
Post Number: 1 Registered: Mar-05
| Posted on Sunday, March 06, 2005 - 01:49 pm: |
whenever i'm trying to convert a file into atrac3, it always gets to 9% then just stops converting, which means nothing ever gets to atrac3. anyone know why this is? its rly annoying! |
godineedadrink Unregistered guest |
| Posted on Saturday, March 19, 2005 - 10:49 pm: |
i'm goin through the same bul$*** right now, there is a problem with one of the security updates for xp, 840987 is the number of it, uninstall it from your comp by going to the add/remove prog window and it might work,i just got fed up with windows and switched to mandrake. |
