Home > Message Board > Portable Electronics > PDAs & Handelds > PalmOne Zire 31 PDA
Author Thread: PalmOne Zire 31 PDA
Username: Morty123
New york
Anyone have any suggestions or solutions relating to the difficulty in reading the screen in bright daylight?
Thanks
If you go into the settings you can turn up the contrast level and it will provide better viewing in daylight hours.
Also this is the lowest price I have found yet on this unit.
PalmOne Zire 31 PDA Cheap
Username: Megshmeg
Ontario
Can Anyone help me to remove a program that I put on my palm. I'm new to this whole thing and can't figure this out for the life of me!
Thanks
JGCK8
How can I get my Zire 31 to receive IR transmissions?
Username: Rbroden
Help! I have a zire 31. I need to customize my calender so that the schedule isn't on the hour (i.e., 8-9, 9-10 etc.) I want to be able to set a default background calender to read 8:00 - 9:15, 9:15 to 10:30, etc. I know I can change this on an invividual appointment through the details page and then the time tag. What I want to do is to change the default mode on all the days to an hour and fifteen minute interval. Any ideas? Any add ons that will do this?
Thanks for any and all ideas.
Rob Roden
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Portable Electronics > PDAs & Handelds > PalmOne Zire 31 PDA [ « Previous ] [ Next » ]
