Home > Message Board > Portable Electronics > Portable DVD Players > Archive through April 09, 2006 > Unlockiing a cyberhome CH-LDV700B
Author Thread: Unlockiing a cyberhome CH-LDV700B
anut4bears
how do i unlock the zone code on my cyberhome CH-LDV700B?
Can you send me the unlock code if you got it, please?tks
Turn the player on
Press MENU
Then press 19 on the remote control
You should get a menu on the screen
Scroll down until you get to Region
Enter 0 for Region Free, or the number of your desired region
Open the tray to exit the menu, and it should work
Hope this helps
Home > Message Board > Portable Electronics > Portable DVD Players > Archive through April 09, 2006 > Unlockiing a cyberhome CH-LDV700B [ « Previous ] [ Next » ]
