Lyra 1070 max MMC size
Username: Jay1028
Can anyone tell me what the max size MMC card that the 1070 can use. I am presently using 128mb and would like to get a 256mb but don't know if it will work in the 1070. The manual gives no info on this subject.
Thanks
justin fleeson
i found this lyra 1071 AND HOW DO I put files on them from my computer
justin fleeson
justin fleeson
jfusco
This is probably too late to answer your question since it was posted in October but I just dropped a 512MB card into my 1070 and it appears to be working fine!
Username: Jay1028
Thank you Jfusco. I was concerned that the 1070 did not have the address lines to
read anything larger than the 128mb that I have been using. I am going to
get a 512MB also.
Bill Mol
Does anybody know why I can't load WMA files purchased from Puretracks.com onto my Lyra 1070?
jamikv
I just bought a 1g card and my lyra 1071 the player isn't recognizing all the memory. is there a limit to the capacity for the expandable memory
jamikv
Username: Baby_joker
i just formated my Lyra 1071 and i put my song's back on there, but it shows that there is 00 song on it so what should i do???????
Dave243243
i formatted my card to FAT16 and it still didnt work....
