Thread: B&Ws or Snells |
New member Username: Bnthouse
Post Number: 1 Registered: 01-2004
| Posted on Tuesday, January 06, 2004 - 11:47 pm: |
im buying a marantz 7400 rec. looking at snell xa60s or the B&W 703s any opinions- my living room has hardwood floors
Relevant Product Info
New member Username: Edison
Post Number: 230 Registered: 12-2003
| Posted on Wednesday, January 07, 2004 - 12:54 am: |
Both are good speakers - a matter of taste. Try to audition them at home - make sure no re-stocking fee, and go with the one that sounds the best to you. You might want to put a rug under the speakers, and have nothing in between them, like a big TV, for better sound. Have you heard onkyo 800 and above? I like their smooth non-fatiguing sound. Rich and pleasantly clear. Won receiver of the year in secrets of HomeTheatre for under 1k. Might want to hear it. www.ecost.com has good price on ts-xr800 refurb. |
Post Number: 2 Registered: 01-2004
| Posted on Wednesday, January 07, 2004 - 01:02 am: |
I have an onkyo 601 now- should I upgrade to the 800?
New member Username: Elitefan1
Post Number: 87 Registered: 12-2003
| Posted on Wednesday, January 07, 2004 - 09:25 am: |
I really like your idea of the Marantz 7400 with Snells. That's the best combo of products mentioned IMO. |
Post Number: 3 Registered: 01-2004
| Posted on Thursday, February 05, 2004 - 01:30 am: |
I went in a little bit different direction I purchased the Snell xa60s with the marantz 7300 and then upgraded and added an anthem amp (mca20)- the sound is great
| Posted on Monday, February 09, 2004 - 04:40 pm: |
TJ: did you test the Marantz with B&Ws. What did you think? |
