Home > Message Board > Home Audio > Receivers > Archives - 2004 > Archive through January 16, 2004 > SONY STR-AV570X???!!! HELP!!!!
Author Thread: SONY STR-AV570X???!!! HELP!!!!
Username: Nugpot
i dont have a manual or whatsoever. my problem is ..it has this blinking red "P" on the screen and renders all function inactive. what does this blinking p means? thanks
Username: Edison
Post Number: 240
Check the speaker cables to make sure thay are not touching any where.
And are your speakers 4 ohm? Some receivers only tak 8 ohm.
Home > Message Board > Home Audio > Receivers > Archives - 2004 > Archive through January 16, 2004 > SONY STR-AV570X???!!! HELP!!!! [ « Previous ] [ Next » ]
