Home > Message Board > Home Audio > Receivers > Archives - 2004 > Archive through January 16, 2004 > KLH 200watt Reciever on (2) 10" Sony ...
Author Thread: KLH 200watt Reciever on (2) 10" Sony Xplod 600watt
Username: Spooky
KLH 200 Watt AM/FM Reciever 100x2 Watts @ 8 Ohms
Model: R-3100
2 (Car) 10" Sony Xplod 600 watt Subwoofers 4ohm
I crank up the Bass knob, and the volume, and the reciever will shut off for no reason when i recieve the volume is set around 30db-35db, if i take off all the bass, i can achieve around 35db-40db before it shuts off
Do i have get some type of conversion to convert the 8ohm (Reciever) to 4ohm (Speaker)? if so can someone help me with this, i am stuck.., i wouldnt know where to look for a OHM Converter at, i know 200watts is enough for 600watt subs, so im all confused why it is shutting off
Username: Edison
Post Number: 217
Get a sub like sony sa-wm200 (www.etronics.com) - affordable and sounds good.
Username: Spooky
But i would like to hook up the speakers i bought, instead of buying new speakers
Home > Message Board > Home Audio > Receivers > Archives - 2004 > Archive through January 16, 2004 > KLH 200watt Reciever on (2) 10" Sony ... [ « Previous ] [ Next » ]
