Thread: Question about the Paradigm Monitor 90P's... |
Brockish Unregistered guest |
| Posted on Monday, January 05, 2004 - 07:55 am: |
Do you think I need sub-woofer in a room 15 X 25 with the Monitor 90P's since the towers have one built in? I have recently bought the (1)CC-370, (2)ADP-370, and of course (2) Monitor 90's this all goes with my NAD 762 which I really love. Is a sub-woofer needed? Of course, the Rep is strongly pushing for the sale. Any thoughts? |
New member Username: Edison
Post Number: 212 Registered: 12-2003
| Posted on Tuesday, January 06, 2004 - 04:20 am: |
A good sub does add something to it, but you can get by without it - hear it both ways and decide for your-self. Some people actually like it better without sub especially for music. I think a good sub adds luxurius warmth. |
| Posted on Tuesday, February 03, 2004 - 06:14 pm: |
it depends on what you are using our stereo for.. if you are just using it for music, you will get more than enough bass in your room. I have my own 90 P's and they are awesome. But if you are watching movies, a sub is definately needed, the bass in the movie won't be channeled to your speakers, and you will be missing out on some of the audio aspect of the movie. I turned my sub off once while watching a movie, and it completley changed the audio, so I suggest that you pick up a cheap sub at least, ad just use it for the movies, any more questions let me know, @ jamesslinkard@hotmail.com |
| Posted on Friday, February 13, 2004 - 10:31 am: |
Well, I ended up getting the pw2200 sub anyway. And let me tell you it makes a diference when watching movies. It totally adds a luxurius warmth and cinematic base that I cannot get with just the 90P's alone. I could have, however, done without it but once it was connected with the rest of the system I will not get rid of it now. When listening to music I do turn off the sub. BTW, my pw2200 sub does get really hot on the back plate of the sub. How normal is this? |
Robert Anderson Unregistered guest |
| Posted on Sunday, February 22, 2004 - 07:35 pm: |
This must be normal because my pw2200 gets hot as well. I have monitor 7s and want to know what would be best for rear speakers. I love my sub. works well with my M7s. Just need a new center and rear speakers. Any advice? |
