Home > Message Board > Home Audio > Receivers > Archives - 2004 > Archive through September 21, 2004 > Need IR codes for my Sony Receiver
Author Thread: Need IR codes for my Sony Receiver
Username: Negative_zero
Brooklyn, NY
United States
not sure if htis is in the right section or not, but i don't have the remote for the Sony STR-DA50ES receiver that i got from a friend (he doesn't have it anymore either) and i can't get my new harmony remote to change the surround genre. tech support couldn't help either, although he did say that if i could find the actual IR code then they could create the command from it.
i'm sure i saw a website a while back that listed the actual IR codes for numerous remotes but i can't find it. if anyone could help me find this site (or one like it) or has any other options that might work, i'd be REALLY grateful.
thanks in advance
~NegZ
Home > Message Board > Home Audio > Receivers > Archives - 2004 > Archive through September 21, 2004 > Need IR codes for my Sony Receiver [ « Previous ] [ Next » ]
