Home > Message Board > Home Audio > Receivers > Archives - 2004 > Archive through September 21, 2004 > Best Receiver for Von Schweikert Syst...
Author Thread: Best Receiver for Von Schweikert System 12 Theater package
VSA convert
For those of you that have or have listened to VSA's LCR 15's, can you please give me your thoughts on the best budget minded 7.1 receiver to match with them.
http://www.vonschweikert.com/surround_systems.html
I am considering the Denon 2805, 2105, or the Marantz 5500. Any thoughts on these or others that are similarly priced?
Username: Landroval
Post Number: 663
To me your receiver choices seem a little cheap compared to the speakers. The 2805 or 3805 could be ok if you like the sound, from Marantz the new 7500 or 8500 should be closer to the class you'll need. Of course NAD T763, T773, H/K AVR7300, Pioneer 56TXi, Rotel RSX-1056 are all safe choices.
VSA convert
Thanks! Unfortunately I'm price constrained to around $700. Can I get your recommendations at anywhere close to that price?
Username: Landroval
Post Number: 664
From here: http://www.soundpros.com/receivers.cfm
You could get the Pioneer 52TX/54TX or H/K AVR430/630 which imo are best choices if you must stay around $700.
VSA convert
Thanks again. I'll check em' out. Anyone else have any additional opinions?
Home > Message Board > Home Audio > Receivers > Archives - 2004 > Archive through September 21, 2004 > Best Receiver for Von Schweikert Syst... [ « Previous ] [ Next » ]
