Home > Message Board > Home Audio > Receivers > Archives - 2004 > Archive through September 21, 2004 > NAD T773 loud sub-woofer "bump"
Author Thread: NAD T773 loud sub-woofer "bump"
Username: Dary
São Paulo
Brazil
Post Number: 9
My 773 started to show a loud sub-woofer "bump" every time a switch surround modes, or press Tone defeat, or change anything in menu - speaker setup. The "bump" makes all room windows shake.
Does anyone experience this problem?
Any suggestions?
Thanks
Daniel Benatar
Not in my NAD T773
Daniel
Username: Gatt767
Malta
Post Number: 70
I had this prob on my T762, replaced the cables with good quality Shielded phono plugs and the prob disapeared
Username: Dary
São Paulo
Brazil
Post Number: 10
Robert,
The problem apppeared last week, after 3 months using the system. I didn´t change anything before the "bump" started to show up. After that I already tried other cables and checked main power phase and ground. Nothing made a difference. I´ll return the unit. Thanks anyway.
Dary
Home > Message Board > Home Audio > Receivers > Archives - 2004 > Archive through September 21, 2004 > NAD T773 loud sub-woofer "bump" [ « Previous ] [ Next » ]
