Thread: Differences between NAD C541, C541-i and C542 |
Bronze Member Username: Alexfromholland
Post Number: 23 Registered: Aug-04
| Posted on Friday, September 10, 2004 - 01:54 pm: |
Hi All, Could somebody explain the difference between the CD players I mentioned ? I know there are some differences with regard to the optical output (541 hasn't got one), but I want to know if there are differences in sound quality ? Thanks! Alex |
| Posted on Friday, September 10, 2004 - 03:48 pm: |
The NAD c542 sounds better, that is if you listen very carefully. When you own the c541i I wouldn't be bothered. Every year models are improved and upgraded and in general they sound better than the previous model. (that is: a little better). You must have loads of money to keep updated. Buying a new cd player means: take the loss, after one year you'll find a better one for the same amount of money. It's a sad world.
Post Number: 24 Registered: Aug-04
| Posted on Tuesday, September 14, 2004 - 01:53 am: |
Thanks for the input, coz I now own a NAD C541 and it sounds great. Only was curious if it's worth upgrading. I'll save the money and keep my C541... |
