Thread: Help - Can I use a Notebook PC as MP3 Jukebox? |
New member Username: Vyoud
Post Number: 2 Registered: 12-2003
| Posted on Tuesday, December 30, 2003 - 06:31 pm: |
How would I go about using my notebook PC as an MP3 jukebox? I have been asked to provide some music for a few private parties and would love to use the MP3 library I have created from all of my CDs and downloads. Do I need to buy an audio PCMCIA card for this? Is there a USB device that would help with interface to mixer/amp? |
New member Username: Project6
Post Number: 82 Registered: 12-2003
| Posted on Wednesday, January 14, 2004 - 06:59 am: |
yes there is a device, however the mixer has to be equipped to accept them. Your best bet is to use a PCMCIA so it can interface with regular equuipment. cheers |
Bronze Member Username: Feot
Houston,
TX
Post Number: 13 Registered: Apr-04
| Posted on Sunday, May 02, 2004 - 01:54 pm: |
the soundblaster extigy is a great usb alternative. |
Unregistered guest |
| Posted on Monday, May 10, 2004 - 01:14 pm: |
I have hooked my Notebook up to my stereo receiver using the headphone jack on the laptop and connecting the "red and whites" to the receiver. The sound however is a bit crap. It distorts, sounds muffled and is generally of low quatlity. Do I need some sort of pre-amp to boost the signal from the laptop? Thanks |
Silver Member Username: Project6
Post Number: 785 Registered: Dec-03
| Posted on Wednesday, June 16, 2004 - 09:39 pm: |
actually you need to find a lower level output than headphone jack outputs. The signal is too high for a receiver's inputs. |
