Thread: B&W 700 series or Paradigm Studio series |
Unregistered guest |
| Posted on Monday, September 06, 2004 - 07:11 am: |
It's my first visit on this forum. I found many hifi enthusiasts and experts here, hopefully can get some opinions from all of you, Thanks. which one will you pick? The B&W 704, 705, HTM7 or The Paradigm studio 40, 20, cc470 and pw2200. They both is my max budget. I'm driving them by Rotel RSP1068 and RMB1075. |
Silver Member Username: Elitefan1
Post Number: 625 Registered: Dec-03
| Posted on Monday, September 06, 2004 - 02:24 pm: |
I would prefer the Paradigm's. I have heard both brands for a long time and for the money nobody produces better bargains than Paradigm. The Studio series is superb and will match perfectly with your Rotel. I like B&W very much as well but if it was my money I'd spend it on Paradigm. |
Silver Member Username: Landroval
Post Number: 619 Registered: Feb-04
| Posted on Monday, September 06, 2004 - 02:33 pm: |
So with Paradigm you would get a sub, but with B&W you wont? If this is the case I would have to agree with elitefan, although I've never even heard the Paradigms. |
| Posted on Monday, September 06, 2004 - 06:01 pm: |
Because the B&W 700 series is very expensive, my budget only allow me to buy those 3. In your opinions, is the Paradigm sound better? I listen to both, they both are good, they look very very nice too. |
