Thread: Troubleshoot H/K receiver!! |
Bronze Member Username: Rlschneck
Post Number: 45 Registered: Apr-04
| Posted on Friday, September 03, 2004 - 09:20 pm: |
Hi everyone, Now I really need help. I got a DVD player that has digital optical out, and I hooked it up to my H/K AVR330 and set the DVD input to Optical 1 (the corresponding input) and at first it gave me the "unlock" message. So, I turned on the dvd player and popped in a dvd, and then it worked, but it gave me this strange message: "PCM 48 Khz". And, the options for Dolby Digital and DTS are still not available. WHAT GIVES!? I read through the manual, and there's nothing in there about this. Can someone please help, I am getting frustrated. I was really looking forward to watching a movie tonight. Thank you, Ryan |
Bronze Member Username: Shank
Pittsburgh,
PA
Post Number: 53 Registered: Aug-04
| Posted on Friday, September 03, 2004 - 09:57 pm: |
R. Schneck, Step back from the audio equipment and take a big breath. First, PCM 48 Khz, means that its sending a stereo digital signal to your reciever. Try to go into the dvd setup menu and find where it has audio settings tell it to send the digital bitstream to the audio server. (and if it has some setting to allow dts, tell it to allow that). have fun :-) and don't get so frustrated, we're here for ya! |
Pittsburgh,
PA
Post Number: 54 Registered: Aug-04
| Posted on Friday, September 03, 2004 - 09:59 pm: |
by server, i meant reciever, so you want digital/dolby/dts bitstream sent to the receiver. |
Post Number: 46 Registered: Apr-04
| Posted on Tuesday, September 07, 2004 - 02:35 pm: |
good ol' shank. i knew i could count on you. i got everything to work...FINALLY! for my first audition of true surround sound, i watched 'saving private ryan.' i bet that's what a lot of people choose as the first movie to try out. anyway, i don't know if you read my post about weak dialog, but my center channel still sounds a little too soft. during the quiet conversation parts of the movie, i can't quite hear what they're saying. do you think maybe my center has something wrong with it? (before you ask, yes, i did the EzSet) I even put the center up one notch (db) after the EzSet was completed. I will have to try some experiments when i get home tonight, to figure out if the speaker is not working properly. Thanks Again, Ryan |
Pittsburgh,
PA
Post Number: 61 Registered: Aug-04
| Posted on Tuesday, September 07, 2004 - 04:17 pm: |
R. Schneck ppl do complain of week dialog quite often, but i almost don't wonder if this is because movies are just much more dynamic. Its not like watching TV at all. It's kinda like listening to the radio and then listening to a symphony in person. So, dvd/ht is meant to be pumped up. If your afraid of disturbing your neighbors and just don't like the movie to be so loud, but still want to hear dialog, try durning the dynamic range to max (i.e. press the "night" button your H/K remote). This compresses the dynamic range of the soundtrack, make softer sections louder (like dialog) and making louder sections softer (like explosions). Next time you goto a movie theater, pay attention to how loud the movie is and how dynamic (the difference in volume between the soft and loud parts) the sound is. |
Gold Member Username: Kegger
MICHIGAN
Post Number: 1415 Registered: Dec-03
| Posted on Tuesday, September 07, 2004 - 05:10 pm: |
shank is on the right track for yu. but you could just do what i do when i'm not cranking the movie late at night. after all your ez is all done press the test button and listen to all the sounds around you then turn up the center until you think it's definatly louder then the right and left speakers. that should bring the voices right in. |
