Home > Message Board > Home Audio > Preamps > Archive through November 28, 2005 > Newbie confused..which set up?
Author Thread: Newbie confused..which set up?
Username: Edean
i have vienna acousic beehtoven in the front with the maestro center, small company in wall rears...anyway, i have been considering a few separtes, but am confused and searching for opinons on the following set-ups:
B&K ref50 w/ 200.5 amp
NAD T163 w/ T973 amp
Adcom GTP860II w/GFA 7805 amp
thanks
ABC
Boy..tough choice...I got adcom 200x3 and 100x2 amps and marantz Av9000 pre/pro and it sounds good.. if I had your choice it would be the Nad system.. I read alot of good reviews on the combo
good luck on your choice
Username: Kegger
MICHIGAN
Post Number: 1409
If I had to pick one of those I would do.
another to consider is the rotel 1068 or 1098 and
apporpiate amp.
for the price the rotel stuff is excelent.
you know any amp can work just fine with any of the prepro's.
and rotel makes nice amps too.
Home > Message Board > Home Audio > Preamps > Archive through November 28, 2005 > Newbie confused..which set up? [ « Previous ] [ Next » ]
