Home > Message Board > Home Audio > Subwoofers > Archive through October 18, 2004 > Looking for correct hookup cable
Author Thread: Looking for correct hookup cable
have a hk avr 230,just received a velodyne cht10 subwoofer,do I need just a cable with rca plugs on both sides?
Username: Bassman61
Adelaide, SA
Australia
I have a HLK avr5550. Theres a subout RCA plug on the back panel of mine (its a mono subout) which i have connected to my sub line in. The model you have should have something similar. i dont know about the sub u are using. If its an active sub ie it has its own amp then it most likely will have a line in RCA jack. I use subwoofer cable made by monster cable. Hope this helps you.
Home > Message Board > Home Audio > Subwoofers > Archive through October 18, 2004 > Looking for correct hookup cable [ « Previous ] [ Next » ]
