Thread: RF Modulator Grief with TX-NR901 |
New member Username: Jastaylor
Post Number: 5 Registered: Aug-04
| Posted on Wednesday, August 25, 2004 - 09:51 am: |
I'm sure this isn't a problem specific to my Onkyo but I have an old TV (hold snickers please) that doesn't even have composite inputs. So I got a little radio shack RF modulator and hooked up my Monitor Out on the receiver to it (its old so its using composite video). 2 Problems arise: 1-Whenever the receiver is on it takes over the TV regardless of video output settings or anything; basically whenever power is on it takes over. 2-It clobbers all channels not just channel 3. not sure if I'm missing a setting somewhere or should just get a newer RF modulator (this ones pretty old) Thx, J |
Silver Member Username: Geekboy
Newport,
RI
United States
Post Number: 350 Registered: Dec-03
| Posted on Wednesday, August 25, 2004 - 10:28 pm: |
RF Modulators basically broadcast the composite signal on channel 3/4. Generally, the RF modulators "disconnect" the antenna connection and broadcast only what's received on the composite jack when in use. I don't know how to overcome that problem without an expensive "combiner". You could try a new RF modulator. It should have a selector to turn it "on and off". That way, you can watch TV -- normally -- while listening to the stereo or doing other things with your receiver. You're not the only one with a modulator. A friend of mine uses one as well. |
Post Number: 6 Registered: Aug-04
| Posted on Friday, August 27, 2004 - 12:32 pm: |
Hmm. Nothing would suck more than something that I have to manually toggle. Maybe I should just by a new TV? What I thought was strange was that the modulator thinks there is a video signal whenever the receiver is powered on. I thought that if I shut the video out off on the receiver it would prevent sending a signal but that doesn't seem to work. |
Newport,
RI
United States
Post Number: 354 Registered: Dec-03
| Posted on Saturday, August 28, 2004 - 06:55 pm: |
Jason: sorry for the delay. Buying a new TV, of course, would quickly solve this issue! Most new televisions have composite and s-video connections (as well as audio) on the rear. This is in additional to the RF coaxial cable input. |
Unregistered guest |
| Posted on Monday, August 30, 2004 - 08:17 pm: |
Hi, I have an old model tv so I bought a RF Modulator to watch dvd's but there are bar lines that run up and down the screen. Any suggestions |
| Posted on Thursday, September 16, 2004 - 10:53 pm: |
you may or may not have figured this out by now, but i'll post anyway: the RF modulator is too 'sensitive', and is picking up tv signals and displaying them as 'ghosts' when you're attempting to watch a DVD. resolution: via the switch at the back of the device, set your RF modulator to the other channel (generally either 3 or 4) from the one that it is currently set to - this should do the trick. worked for me... ;] bdb |
