Home > Message Board > Home Audio > Mini Systems > JVC MX-GA77.. adding on?
Author Thread: JVC MX-GA77.. adding on?
Username: Tyler2k3
Hi, I just got this system for christmas. It doesn't produce anywhere near the bass I was hoping to hear. Is it possible to add a separate subwoofer. Also I would probably also need another amplifier.. as the sub I would buy probably would be too big for this system. Thanks for any help on what my options are.
Username: Edison
Post Number: 81
You first might want to check if you can boost the bass by adjusting the equalizer or bass function.
It should have pretty good bass - with adjustment.
If you still want more, you can add this sony sub for less than $100 :
http://www.tvcity.tv/productview.aspx?ID=245
If you can return it, you can get panasonic sc-ak410 which has decent bass and sound (ebay).
Username: Bobsy
had a jvc mxga77 a while but now the cd drawer will not stay shut when i press close it just re opens straight away so now i cant play a cd does anyone know what is causing this or how to fix it
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Home Audio > Mini Systems > JVC MX-GA77.. adding on? [ « Previous ] [ Next » ]
