Thread: Help with Installation |
New member Username: Zorro75
Grand Prairie,
Texas
United States
Post Number: 1 Registered: Aug-04
| Posted on Saturday, August 21, 2004 - 09:02 pm: |
To whom it may concern I bought a Pioneer DEH 16 and I'm having trouble hooking it up. I'v connected the Speakers wire according to the color code and they seem to be fine, there's a black which is the ground and that is okay also. the problem I'm having is that there is a yellow, a Red and a Blue/white. When the Yellow is connected to the Hot Lead at approx 11 decibels the unit starts to blink, when I reverse the wiring I have to reset the Stations, don't know what to do with the Blue/White Wire. I have a 97 Camry and there's a built in apparatus (don't know if it is a crossover or preamp). Any help would be greatly appreciated. Thanking You in advance Zorro75 |
Silver Member Username: Edison
Glendale,
CA
US
Post Number: 509 Registered: Dec-03
| Posted on Monday, August 23, 2004 - 03:01 am: |
Post it on "car audio" and you will get help. |
