Home > Message Board > Home Audio > Amps > Archive through October 30, 2004 > Plate amplifier
Author Thread: Plate amplifier
mckenzie
Hello
today i tried hooking up a home audio sub with a built in amp up to my minisysytem. My minisystem has rca inputs. I tried hookin up the sub through that but it did not work. it did work though if i used speaker wire. When i hook it up using speaker wire am i using the amplifier built into the boxes power or the minisystems power.
thanks alot
Username: Kegger
MICHIGAN
Post Number: 1170
your using the speaker box power.
also you need an rca output from your minisystem
not an input.
mckenzie
well all i no is i have the red and white plugins on my mini system and the amplifier. so your saying if i use speaker wire from my minisystem to the amplifiers im using the plate amplifiers power not the minisystems.
thanks alot
i am interested in making all of my boxes powered units , but i have very little knowledge of sites where i can find these units, especially high powered, high quality ones for sale. any help or information will be greatly appreciated
Username: Natediggidy
Baltimore, Maryland
U.S.A.
Post Number: 45
Is this what you need?
http://www.partsexpress.com/webpage.cfm?webpage_id=3&SO=2&&DID=7&CATID=43&Object Group_ID=505
Home > Message Board > Home Audio > Amps > Archive through October 30, 2004 > Plate amplifier [ « Previous ] [ Next » ]
