Thread: MiniDisc data recovery - Deleted tracks |
Unregistered guest |
| Posted on Thursday, August 05, 2004 - 02:18 am: |
Hello, hope someone can point me in the right direction. I have also posted to another board with no joy. I've got an 80 min minidisc recorded in Mono mode, which had a 30 min recording of a telephone conversation on it. I thought i had transferred it to my MAC, so I then deleted the track off the minidisc. It was then i found that the track did not copy over properly, can i recover this minidisk track data. The disk now says that its empty. (I know ive been dumb.) TA. Tina tina_bunt@musician.org |
| Posted on Thursday, August 05, 2004 - 02:27 am: |
Hi tina, no worries i can recover all the info on your minidisc. Contact me and i will mail you the shipping details. Im in the UK. I dont charge a fee but a donation towards the hardware used to pull the data off the disks always helps future development of the techniques to help more people. Let me know. Mark mark0958@hotmail.com
| Posted on Thursday, August 19, 2004 - 03:42 am: |
I do all my minidisc recovery on a consumer range machine and it takes about 15secs to recover a complete disc. Anything up to a mds980 from an older machine will do - see minidisc.org. |
| Posted on Friday, January 21, 2005 - 12:43 pm: |
Hi, I've got more or less the same problem than Tina. I tried to transfer audio data from an Sony MZ-NH1 to my computer, but the program (Sonic Stage) interrupted the process and automatically deleated all the data from the Hi-Mini-Disc. Do you guys have any ides what to do next? The audio data was for my diploma thesis
Asa bergstrom Unregistered guest |
| Posted on Saturday, March 19, 2005 - 09:05 am: |
Hello, hope someone can help. I've got an 74 min minidisc recorded in normal mode I then deleted all the tracks by mistake. Asa asabergstrom1@mail.com
Mark_arcade Unregistered guest |
| Posted on Saturday, March 19, 2005 - 09:17 am: |
Hi Asa, "Minidisc Data Recovery" As i said above, i will be able to recover your deleted minidisc audio data, if it is that important to you. Let me know if i can help. Mark. Mark0958@hotmail.com |
| Posted on Sunday, May 01, 2005 - 07:44 am: |
I have a Sony Hi-MD MZ-RH910. I recorded one of my bands gigs with it. I recorded with an 80 min disc in Hi-SP mode. While trying to transfer the songs using SonicStage 3.0, I got an error and it shutdown the program. Now when I try to play the disc I get a format disc error and a message saying it needs to be formatted. Can I still recover the audio tracks from the disc? Thank you |
| Posted on Monday, May 23, 2005 - 08:52 am: |
Hi, I have a sony MZ-NH1 and I recorded my tracks on Hi-MD LP format, but after recording for about 400MB, I get a disc full message (although there is 600MB left and 23hrs of recording available). I press record again, and the unit records, but after this, every single track on the disc (including the old ones) is damaged and I get no sound for any of them. I remove the Hi-MD disc and insert it again and I get a format error on the unit. This has happened twice now. All the recordings are so important to me and I had no back up!! Anyone know what I can do, or how I can recover these tracks?? I had only 7 groups on the disk and a total of about 400 tracks. Thanks |
Marjorie Unregistered guest |
| Posted on Tuesday, August 02, 2005 - 01:19 pm: |
Hi, I have another recovery problem - I have a minidisc that had about 4 hours of interivews on it that I somehow deleted. I was creating a new track to come back to the same place later and somehow the TOC came on and (unknown to me at that moment)it deleted the entire disc as I put the machine away. Unfortunately, I have taken the disc out and in my frustration to see what was wrong actually recorded a few seconds onto the disc to see if it was working (I know that was REALLY stupid). I thought all was completely lost (and maybe it is) because the manual says the info is not retrievable, but somebody told me to look online and here I am. If you can help let me know. Thanks! |
| Posted on Wednesday, October 26, 2005 - 04:45 am: |
Hey, those who face the problem that your live recording stopped unexpectedly (for example coused by power failure). This means that your recorder didn't have enugh time to complete TOC-table. Solution to recover audio (not tracks): 1. You need a MD that is long as your original MD (that has failed recording on it) 2. Record it full of audio (so you have now TOC table on it that tells to MD-player you have one 74 minute track for example) 3. You need a MD recorder that has abilities to split or merge tracks. And it also must have ability to complete writing TOC after power failure. (For example Sony MDS-E10) 4. Now comes recovery part: a) insert your own made MD that is full of audio or that has two tracks that fill whole MD b) edit tracks somehow (for example merge those two tracks or split one track) - IT IS CALLED TOC EDIT or RAM EDIT c) IT depends on recorder but supposedly TOC sign blinks on display to mark that recorder needs your confirmation to finalize TOC edit (to write new TOC to the beginning of your MD) d) UNPLUG your recorder e) Dangerous part - uncover your recorder and try extremely gently to remove your MD from recorder. Beware, it is extremely dangerous because there is always a chance to break the mechanics that drive MD. f) insert the MD that has failed recordings on it g) PLUG IN the recorder h) recorder draws new MD inside and finalizes the TOC (recorder thinks that it is the same old MD with the tracks you merged or splitted) i) Congradulations! Now you have a MD with one long track on it, but at least you recovered sound. Play the MD, if player reaches to the point your recording ended it stops automatically (because there is no audio format from tihs point if you used blank disk).
| Posted on Wednesday, November 09, 2005 - 06:30 am: |
I too have had a problem with my TOC being lost after making a live recording. I have tried opening my Sharp MD-MT866 but I don't seem to be able to extract the mini disc if it still needs a TOC write. If anyone can help me recover the data on my disc I would be greatful. I have seen there is a company charging £75 for the service but that is way out of my league. |
| Posted on Friday, November 11, 2005 - 02:42 am: |
I have finally managed to recover my TOC using my Sharp MD-MT866. I had tried recording a whole disc with one track and then splitting a track after 30 seconds and deleting it. This left the machine wanting to write a toc if you removed the battery at that point. However I could not remove the disc. I tried unscrewing the lid but again got nowhere and then had problems with the machine thinking the lid was open. Now weather I have then not put the machine back together or not I can't tell but a useful side effect is if I remove a disc it still seems to be playing as far as the machine is concerned. I was actually using a piece of string to spring the door catch again I am not sure this was necessary. I was therefore able to put the full disc with one track in and play it and then switch discs and carry on playing my TOCless disc. I then had trouble with the disc being Protected. I somehow managed to get this sorted by removing the battery and starting again and then I was able to save my new TOC. Yippee |
| Posted on Wednesday, November 23, 2005 - 02:40 pm: |
more himd transfer erasures. Has anyone found someone who can recover unintentionally erased HiMD discs. I had a career highlight on this disk which erased everything when the transfer was interupted. try me at andrumclean@yahoo.com. thanks |
New member Username: Richard111
Post Number: 1 Registered: Mar-06
| Posted on Sunday, March 19, 2006 - 02:02 pm: |
I'm now offering a minidisk recovery service for anyone interested. You can contact me at rddion@prodigy.net . Thank You Rick |
New member Username: Rgoodman
Santa Cruz,
CA
Post Number: 1 Registered: May-06
| Posted on Wednesday, May 03, 2006 - 08:17 pm: |
Here's my problem: Recorded a wonderful interview on Hi-MD Sony MZ-NH9800 machine. Battery went dead, unit shut down. Plugged it into wall socket and kept recording.Noticed, but did nothing about the observation that this was again track 4, as had been the first (possibly lost) interview. Is there any chance my interview is still in there and can be extracted, even part of it? I don't have much to spend, and was wondering if I went through "Search and Recover" program and made an image of the uploaded data, then tried to read it with some kind of conversion program, whether that would do it. I'm over my head and may have to do the interview over, but I'd rather not. Any advice? |
New member Username: David86
| Posted on Thursday, May 04, 2006 - 12:22 pm: |
Hi First time(one year ago) i tried to upload my music onto my computer i uploaded it with sonicstage but i couldnt burn it so i tried without sonicstage.. This also didn t work so i tried again with sonicstage, but it just erased my file from my disc. Now i only have the file wich i uploaded without sonicstage. Is there a way to recover this file ( its a pianoexam from a friend)? |
New member Username: Kim_ranfeltreklamehotmailcom
Post Number: 1 Registered: Nov-07
| Posted on Saturday, November 03, 2007 - 06:34 pm: |
Data recovery from MiniDisk - Easy if you have the right machine!! Hi Everybody I just managed to save the data on my MD. I created a new TOC (table of content) by removing the cover, fix the open lid censor and shifting minidisk. In this way I trick the machine to think it was the same disk, and the new TOC can be written witch enables me to play the erased data. It is possible on my SHARP MD-MT66, because it waits to write the TOC until you open the lid or turn the machine of. It would not be possible though on my SONY MZ-RH1 because it does the “TOC” (called SYSTEM WRITING) right after you stop the editing. As you might have guessed I was inspired by krebelo (scroll up) but it works with every kind of formatted and erased MD, because the only thing that is changed is the TOC. As far as I know it is the same fore all kinds of data consisting of 0/1 (bits and bites). Just fix the TOC - or what ever the contend file is called - and your on. Best regards Kim For questions: kim_reklame@hotmail.com |
New member Username: Slo007
Post Number: 1 Registered: Apr-09
| Posted on Friday, April 17, 2009 - 04:57 am: |
Anyone manage to recover deleted track on Hi-MD? |
New member Username: Supermagician
Post Number: 1 Registered: May-09
| Posted on Sunday, May 17, 2009 - 11:50 pm: |
hi,last weeks,my computer's disk files was lost.i'am very troublou.at last ,i find a sowtware "DERescue Data recovery master" help me to get back the data.perhaps it may help you. |
New member Username: Slp3
Post Number: 1 Registered: Jul-09
| Posted on Thursday, July 23, 2009 - 04:52 pm: |
I recorded a live set, hit stop. it said it was there as normal saved. take disc out, power off. get home put in and it says "Blank Disc" tried just now 2 record something new for 3 seconds, did the same process. power off, then on, put back in now it works? it saved that recording. Help
New member Username: Barbalucian
Post Number: 1 Registered: Sep-09
| Posted on Tuesday, September 08, 2009 - 09:16 am: |
Hi S, exactly the same thing just happened to me an hour ago. I had a great interview on Friday, took the disc out today to transfer it as I normally do, put it in my domestic machine and it said "Blank Disc". I nearly fell on the floor. I put it back into the portable, it said "Blank Disc". So, I made a short recording which was fine, but I know that the "lost" data must still be on the disc, I'm in a pickle too mate - H E L P - M E - P L E A S E - S O M E O N E ! |
Post Number: 4 Registered: Mar-06
| Posted on Tuesday, September 08, 2009 - 08:49 pm: |
I have a service for recovering regular MDs. I charge 15$ and I'm located in North Easton, MA. You can contact me at rickk6d@yahoo.com for all the details or any questions. Thanks Rick |
New member Username: Reehana
Post Number: 1 Registered: Nov-09
| Posted on Wednesday, November 11, 2009 - 10:50 am: |
Hi I hope that you will be able to fix my mini dvd disc,which comes up as unknown because I did not finalise it before I took it out of the camcorder. It shows up as formatted on the camcorder, but I cant lose these files, coz they are video clips of my 1 year old girl and very precious to me. Sony Handycam DCR-DVD106 (Sony DCR DVD handycam camcorder videocam Disk access error) Please contact me with with costs if you can help solve my problem, Email ryedale@gmx.com Thank you Reehana |
