Home > Message Board > Home Audio > Integrated Amps > Archive through July 25, 2005 > Zone free for LG DVD's DV6812P and V8...
Author Thread: Zone free for LG DVD's DV6812P and V8824W
Username: Naomie
Hi - can anyone give me the codes to make LG dvd models DV6812P and V8824W zone free???
FBI
This section is for Integrated Amps!
catch22
Changing the region on this player V8824W
To perform the correct sequence of steps you will only need access to your players front panel and its remote control. Always make sure that the drive tray is empty before following the procedure listed below.
Power on your DVD player & then do exactly what is given below.
1. Press the Pause button on your remote control
2. Press the 3 button on your remote control
3. Press the 1 button on your remote control
4. Press the 4 button on your remote control
5. Press the 1 button on your remote control
6. Press the 5 button on your remote control
7. Press the 9 button on your remote control
8. Press the 1 button on your remote control for region 1, the 2 button for region 2, and so on, or the 0 button for multi-region playback
9. Press the Pause button on your remote control
10. Power off your DVD player
11. Power on your DVD player
Now you can enjoy DVD's from all regions
Thank you very much for the code. It also worked perfectly for my LG Slim DS8521P DVD player. May be good to work with all LG DVD Players.
Reon
THAAANKS HEAPS for the V8824W Region Free God Bless You all!!!!
Home > Message Board > Home Audio > Integrated Amps > Archive through July 25, 2005 > Zone free for LG DVD's DV6812P and V8... [ « Previous ] [ Next » ]
